查看: 3016|回复: 0
[驱动] 大恒图像Linux/ARM Linux系统Python驱动Galaxy_Linux_Python_2.0.2103.9101
  • 签到天数: 3859 天
    连续签到: 52 天
    发表于 2021-7-8 16:15:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Galaxy_Linux_Python_2.0.2103.9101.tar
    V2.0.2103
    语言:中文/英文
    相机:USB3.0 / USB2.0 / GigE
    系统:Linux、ARM Linux
    软件描述:
    软件说明
    更新说明
    V2.0.21.03:
    1.添加注册/注销掉线回调
    2.添加注册/注销采集回调
    3.同步最新的FeatureID
    4.添加回调方式采集示例程序
    链接:
    提取码:4kra
    大恒官方下载:
    Readme
               INSTALL INSTRUCTIONS
                   2020-01-13
    BEFORE INSTALLATION
    Before installing the Galaxy python, Galaxy Linux SDK should be installed first. Otherwise, the python library will not work properly.
    Galaxy python installation for Linux
    Python2.7 gxipy installation
    1.Install python2.7 & python2.7-dev
      (1) sudo apt-get install python2.7
      (2) sudo apt-get install python2.7-dev
    2.Install the python-setuptools toolkit
      (1) sudo apt-get install python-setuptools
    3.Install gxipy library
      (1) cd ./api
      (2) python setup.py build
      (3) sudo python setup.py install
    4.Install numpy library
      (1)First method by pip:
         1)sudo apt-get install python-pip
         2)sudo pip install numpy
      (2)Second method by numpy source code:
         1)Download source code
              wget http://jaist.dl.sourceforge.net/ ... 9.0/numpy-1.9.0.zip
         2)unzip numpy-1.9.0.zip
         3)cd numpy-1.9.0
         4)sudo python setup.py install
    Python3.5 gxipy installation
    1.Install python3.5 & python3.5-dev
      (1) sudo apt-get install python3.5
      (2) sudo apt-get install python3.5-dev
    2.Install the python3-setuptools toolkit
      (1) sudo apt-get install python3-setuptools
      (1) cd ./api
      (2) python3 setup.py build
      (3) sudo python3 setup.py install
         1)sudo apt-get install python3-pip
         2)sudo pip3 install numpy
         3)cd numpy-1.9.0
         4)sudo python3 setup.py install
    >= Python3.8 installation notice
      Before installing >=python3.8, you should install libffi-dev first.
         sudo apt-get install libffi-dev
    Document
    doc_en: English version document
    doc_cn: Chinese version document
    Attention
    The sample may depend on third party libraries(e.g. PIL), please install it by yourself.
    GMT+8, 2026-4-17 10:17
