查看: 1613|回复: 1
[驱动] 大恒图像Linux/ARM Linux系统Python驱动Galaxy_Linux_Python_2.4.2503.9202
  • 签到天数: 3859 天
    连续签到: 52 天
     楼主| 发表于 2025-5-8 08:08:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Galaxy_Linux_Python_2.4.2503.9202.zip
    V2.4.2503
    文件名: Galaxy_Linux_Python_2.4.2503.9202.zip
    文件大小: 3771757 字节 (3.60 MB)
    修改日期: 2025-04-07 09:01
    MD5: 08139fc089eb9f6977576d0ea3dac157
    SHA1: d201f28e2e86a13348c5c3aff931cf54e4b5b243
    SHA256: 431eb81f1493a278064c5a3916bf459a38dfb05d3bbd2d3f0ba601b7c7d326c8
    CRC32: 82ce72ea
    语言:中文/英文
    相机:USB3.0 / USB2.0 / Gige
    系统:Linux、ARM Linux
    软件描述:
    软件说明
    更新说明
    V2.4.2503
    1.添加字符串功能接口以及interface层接口
    2.添加action命令接口
    3.支持日志功能
    4.同步最新的图像处理功能
    V2.0.2106
    1.添加设备重连接口以及调节亮度、镜像等图像处理库接口
    百度网盘下载地址:
    链接:https://pan.baidu.com/s/1hKLOqPQMxVaLizAlvomUgQ
    大恒官方下载地址:
    自述说明:
               INSTALL INSTRUCTIONS
                   2020-01-13
    BEFORE INSTALLATION
    Before installing the Galaxy python, Galaxy Linux SDK should be installed first. Otherwise, the python library will not work properly.
    Galaxy python installation for Linux
    Python2.7 gxipy installation
    1.Install python2.7 & python2.7-dev
      (1) sudo apt-get install python2.7
      (2) sudo apt-get install python2.7-dev
    2.Install the python-setuptools toolkit
      (1) sudo apt-get install python-setuptools
    3.Install gxipy library
      (1) cd ./api
      (2) python setup.py build
      (3) sudo python setup.py install
    4.Install numpy library
      (1)First method by pip:
         1)sudo apt-get install python-pip
         2)sudo pip install numpy
      (2)Second method by numpy source code:
         1)Download source code
              wget http://jaist.dl.sourceforge.net/ ... 9.0/numpy-1.9.0.zip
         2)unzip numpy-1.9.0.zip
         3)cd numpy-1.9.0
         4)sudo python setup.py install
    Python3.5 gxipy installation
    1.Install python3.5 & python3.5-dev
      (1) sudo apt-get install python3.5
      (2) sudo apt-get install python3.5-dev
    2.Install the python3-setuptools toolkit
      (1) sudo apt-get install python3-setuptools
      (1) cd ./api
      (2) python3 setup.py build
      (3) sudo python3 setup.py install
         1)sudo apt-get install python3-pip
         2)sudo pip3 install numpy
         3)cd numpy-1.9.0
         4)sudo python3 setup.py install
    >= Python3.8 installation notice
      Before installing >=python3.8, you should install libffi-dev first.
         sudo apt-get install libffi-dev
    Document
    doc_en: English version document
    doc_cn: Chinese version document
    Attention
    The sample may depend on third party libraries(e.g. PIL), please install it by yourself.
  • 签到天数: 1 天
    发表于 2026-4-1 21:54:42 | 显示全部楼层 来自:北京市 联通
    GMT+8, 2026-4-17 10:16
