查看: 2111|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 20.6 Win32/64Eng LTE/LTE演进蜂窝测试软件20.6
    昨天 08:10
  • 签到天数: 3858 天
    连续签到: 51 天
     楼主| 发表于 2022-7-13 12:21:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2021/1/20
    包含的版本:20.6
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    完整版校验和:
    文件大小: 947834880 字节 (903.93 MB)
    修改日期: 2022-03-25 11:13
    MD5: 34259aae4313b6529079225458360d87
    SHA1: e4afcf42b8c7de8bdd7e6336e6550c1f6e826dda
    SHA256: 2adeb599df6c31da21353e3fedc3e31b41ecaf71da54174ce3581ea04368339a
    CRC32: d7daecf9
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE20.6.txt (545 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 599930880 字节 (572.14 MB)
    修改日期: 2022-03-25 11:36
    MD5: 3df3c241b4f4b936eb082df772bd6ecd
    SHA1: 1057c635513667c8c3470112715adc157ad43a62
    SHA256: 69de20bbada60532db39c16fab91938d7794664f71d31f44176515c714dd7166
    CRC32: aa32c1b2
    NI官方下载和百度网盘下载地址:
    RFmx LTE20.6RTE64.txt (569 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 596992000 字节 (569.34 MB)
    修改日期: 2022-03-25 11:50
    MD5: abbff441a1fc5aa2c57f3176c42901aa
    SHA1: 96be41911090ab05fb7a1c9f9f373cb4609b2595
    SHA256: b7548629e6dd2af71fce76bbe3d8fd60a805270809eef717de8a9b976eb11c56
    CRC32: 6fc96668
    NI官方下载和百度网盘下载地址:
    RFmx LTE20.6RTE32.txt (581 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx LTE 20.6 Readme
    January 2021
    RFmx LTE Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx LTE is an optimized API for performing physical layer measurements on LTE cellular standard signals. RFmx LTE is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. RFmx LTE additionally supports NB-IoT/eMTC and LTE-V2X.
    RFmx LTE 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx LTE 20.0 includes the following new features:
    • Support for TM 2b and TM 3.1b downlink test Models
    • Support for demodulation of PSSCH in the presence of PSCCH for LTE-V2X
    • Addition of spectrum emission mask for CA Bandwidth Class B
    RFmx LTE 19.1 includes the following new features:
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    • Support for LTE-V2X or sidelink. Supported measurements are ModAcc, ACP, SEM, CHP, and OBW
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx LTE 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx LTE dropped support for all 32-bit Windows operating systems. RFmx LTE will not install or run on an unsupported OS. Refer to RFmx LTE Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx LTE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx LTE 20.6 to an unsupported OS. Additionally, after installing RFmx LTE 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx LTE supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx LTE. To add support for application software installed after installing RFmx LTE modify your RFmx LTE installation or launch the RFmx LTE installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx LTE
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1, 2020
    NI installs RFmx LTE using NI Package Manager. If you do not already have NI software installed, RFmx LTE installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx LTE. For more information on RFmx LTE activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx LTE » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx LTE palette VIs are available from the Functions » Measurement I/O » NI-RFmx » LTE palette.
    Documentation for RFmx LTE is located at Start » All Programs » National Instruments » RFmx LTE » RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx LTE HelpHTML/Windows HelpContains primary help content for RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx LTE
    • A complete reference for all RFmx LTE programming functions and VIs
    RFmx LTE 20.6 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx LTE examples at Start » All Programs » National Instruments » RFmx LTE » RFmx LTE Examples.
    The following items are behavior changes in RFmx LTE 19.1 from RFmx LTE 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxLTE Analyze (IQ) and RFmxLTE Analyze (Spectrum) APIs. Use RFmxLTE Analyze (IQ, 1 Wfm) and RFmxLTE Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx LTE 19.0 from RFmx LTE 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    The following items are the behavior changes in RFmx LTE 3.0 from RFmx LTE 2.5.
    • ModAcc synchronization algorithm assumes that all component carriers are time aligned.
    You can access the RFmx LTE known issues list online at RFmx LTE 20.6 Known Issues.
    You can access the RFmx LTE bug fix list online at RFmx LTE 20.6 Bug Fixes. This list describes a subset of issues fixed in the RFmx LTE. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx LTE will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2015–2021 National Instruments. All rights reserved.
    375558M-01
    GMT+8, 2026-4-17 07:05
