查看: 160|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2026 Q1 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件26.0.0
    12 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2026-3-19 10:17:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx GSM/EDGE+
    发布日期:2026/1/28
    包含的版本:2026 Q1完整版/运行版,版本号26.0.0
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2666090496 字节 (2.48 GB)
    修改日期: 2026-02-07 16:36
    MD5: a824fa55b79d3d8c7d78583ed868a68b
    SHA1: d6b12b8e5a8881139ccdc1996a70ad282c4debd3
    SHA256: 6f76f508e451a91b135cd8d9d098f4fd61e25d066c5296db07bbf99f16018e65
    SHA512: d29b7c4163649373a79306a742ceb24d4a9dd90eb2e4e34c59674ff6d21c320c3948b0b2ec08e24b035001da4eddcc09121fea652a34ae8b80cc3f59ba43319c
    NI官方下载和百度网盘下载地址:
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM 2026 Q1.txt (677 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1015193600 字节 (968.16 MB)
    MD5: 8cf9d4f6a3df1c2d59548b07660bcb62
    SHA1: 81507e3be097856f93f9f0cf69d294d465eec4af
    SHA256: 53ea4485674deed16d1c6770de3b467bebdf9939b263dc687afe5d30c0c660a5
    SHA512: ac9ac3a8f35a5e3095e7fbca1f1f5b984e0ba1fee99d081e5884845f8b7b279263425118ae0fe094b90c00c5593fabe7c15bc35169f4eab94792398f093d1a7d
    NI官方下载和百度网盘下载地址:
    RFmx GSM 2026 Q1RTE.txt (702 Bytes, 下载次数: 0, 售价: 5 圆)
    2026Q1版未更新自述文件,参考2023Q3版本
    RFmx GSM 2023 Q3 Readme
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM 2023 Q2 includes the following new feature:
    RFmx GSM 2023 Q1 includes the following new feature:
    RFmx GSM 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for configurable RBW in PVT measurement.
    RFmx GSM has the following requirements:
    RFmx GSM 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2023 Q3 to an unsupported OS. Additionally, after installing RFmx GSM 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx GSM (64-bit only)
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following is the behavior change in RFmx GSM 2023 Q3 from RFmx GSM 2023 Q2
    The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3
    • RFmx GSM drops support for 32-bit user mode.
    The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    GMT+8, 2026-4-8 20:32
