NI RFmx CDMA2000 2026 Q1 Full/Runtime Win11 64bitEn RFmxCDMA2K完整版运行版26.0.0下载
RFmx CDMA2000
发布日期:2026/1/28
包含的版本:2026 Q1完整版/运行版,版本号26.0.0
Windows Server 2025
64位完整版校验和:
文件大小: 1421531136 字节 (1.32 GB)
修改日期: 2026-02-07 16:38
MD5: 9ec4cd4354f4da434295b98598eb934d
SHA1: aed0904c0df07be5be2f8858a415465d88cef0cf
SHA256: 1b7088a15b447dfcf9d4db54cbb27a70399f048ad6193329584c148bd2f10bff
SHA512: a95f2d214f3a55745132c204e1ae3a8a2e9567791a5271a1fb58e28c4f043af724198b617376d18a473ac9ab185ee68d3f2aa90df9093f41b72d8d497d8dbb01
请注册登录视觉论坛,购买附件查看下载地址
RFmx CDMA2000 2026 Q1.txt
(685 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 1030225920 字节 (982.50 MB)
MD5: 32297167fb8337bfeb7fbb0b1b3fb4da
SHA1: 0155fe4ad4b9356715c62e292e9b34f6b6914ad0
SHA256: fdee668392022e39c3c969356ec10a648b5da65b8cc1c9ec4fb40028bb246102
SHA512: 43ab112d1f02d1113d2cd6c41e1137ba16baa52ae21cc2925812c6a8fd3b8802885ca8fd720812dbab8af85b97857f63d4a34fa293327f1846397e301a7e4c62
RFmx CDMA2000 2026 Q1RTE.txt
(710 Bytes, 下载次数: 0, 售价: 5 圆)
2026Q1版未更新自述文件,参考2023Q3版本
RFmx CDMA2k 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx CDMA2k, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx CDMA2k 2023 Q2 includes the following new feature: - Speed improvements for Composite and Spectral measurements
RFmx CDMA2k 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
RFmx CDMA2k 2022 Q4 includes the following new features: - Support for PXIe-5842
- Support for Downlink link direction in CDMA2k ModAcc measurement.
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx CDMA2k has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx CDMA2k (64-bit only) | | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx CDMA2k .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx CDMA2k .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx CDMA2k installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx CDMA2k. For more information on RFmx CDMA2k activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files (64-bit) | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel. Accessing the APIRFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette. Accessing the DocumentationDocumentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation. Finding ExamplesYou can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3 - RFmx CDMA2k drops support for 32-bit user mode.
The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
The following items are behavior changes in RFmx CDMA2k 19.1 from RFmx CDMA2k 19.0. - Obsoleted RFmxCDMA2k Analyze (IQ) and RFmxCDMA2k Analyze (Spectrum) APIs. Use RFmxCDMA2k Analyze (IQ, 1 Wfm) and RFmxCDMA2k Analyze (Spectrum, 1 Wfm) APIs instead
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
