查看: 2086|回复: 0
[NI软件产品] NI RFmx LTE/LTE Advanced 21.8.2 x64Win10 32/64bitEng LTE/LTE演进蜂窝测试软件21.8.2
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-13 12:42:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx LTE/LTE-Advanced
    发布日期:2022/6/30
    包含的版本:21.8.2
    完整版校验和:
    文件大小: 1130637312 字节 (1.05 GB)
    修改日期: 2022-06-30 09:47
    MD5: ba5f594e09e3728beafef2256b1d8d76
    SHA1: 3ee6d256efa68fe529e2102deccdf341a598aa79
    SHA256: 5acb53d09a108d5403d2073df1a914b5a062fdbfbdade63d490f8d74756a1c17
    CRC32: 3239ec65
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx LTE21.8.2.txt (546 Bytes, 下载次数: 2, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 617312256 字节 (588.71 MB)
    修改日期: 2022-06-29 21:48
    MD5: dc3a229d3cb4f9d5c60e4e0514da079b
    SHA1: 32078983e0c918a6d6e0a51b9c765c25fec8be5c
    SHA256: d136d7e1ff3251a0c2233d6beef7c45a2ed35e939f6cbb0b85db544e0d387124
    CRC32: 9ce8aca8
    NI官方下载和百度网盘下载地址:
    RFmx LTE21.8.2RTE64.txt (571 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 612521984 字节 (584.15 MB)
    MD5: b0773e04693832def1f4aa8141e9e847
    SHA1: db60d2082cad324a394055b497d4c1b17cbd3d91
    SHA256: 6c5640464c926af45216934bd7deec5d29c141759809d0b67c37f776363d8541
    CRC32: 653e757b
    NI官方下载和百度网盘下载地址:
    RFmx LTE21.8.2RTE32.txt (583 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx LTE 21.8.2 Readme
    May 2022
    RFmx LTE is an optimized API for performing physical layer measurements on LTE cellular standard signals. RFmx LTE is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. RFmx LTE additionally supports NB-IoT/eMTC and LTE-V2X.
    RFmx LTE 21.3 includes the following new features:
    • Support for user-defined overlap (%) for Sequential FFT measurement method in ACP
    RFmx LTE 20.7 includes the following new features:
    • Support for IQ impairment compensation in uplink
    • Support for Time Alignment Error (TAE) measurement in downlink
    RFmx LTE 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx LTE 21.8.2 supports the following 64-bit operating systems:
    Note    RFmx LTE no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx LTE 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx LTE 21.8.2 to an unsupported OS. Additionally, after installing RFmx LTE 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Application SoftwareVersions Supported by RFmx LTE
    ItemInstalled Location
    Import Library files
    Select Start » National Instruments » RFmx LTE » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx LTE palette VIs are available from the Functions » Measurement I/O » NI-RFmx » LTE palette.
    Documentation for RFmx LTE is located at Start » National Instruments » RFmx LTE » RFmx LTE Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx LTE HelpHTML/Windows HelpContains primary help content for RFmx LTE. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx LTE
    • A complete reference for all RFmx LTE programming functions and VIs
    RFmx LTE 21.8.2 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx LTE examples at Start » National Instruments » RFmx LTE » RFmx LTE Examples.
    The following items are the behavior changes in RFmx LTE 21.8 from RFmx LTE 21.5
    • Obsoleted Subblock Freq Definition property. Use Subblock Freq (Hz) property for configuring subblock frequency offset from the center frequency.
    The following items are the behavior changes in RFmx LTE 20.7 from RFmx LTE 20.6
    375558V-01
    GMT+8, 2026-2-3 06:38
