查看: 1850|回复: 0
[NI软件产品] NI RFmx NR 20.6 Win32/64ENG RFmx 5G新空口蜂窝测试20.6
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-7-14 10:00:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    发布日期:2021/1/20
    包含的版本:20.6
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    完整版校验和:
    文件大小: 1350217728 字节 (1.26 GB)
    修改日期: 2022-03-25 12:22
    MD5: d3497bd2f0a31be65db748af1a8bd5cb
    SHA1: e673d7123cc63681fea94cff6df2b473d0a8b6e2
    SHA256: b88b66d08eba1edb9a2b1e969fd3ff2dec7a3a87e07274206c92055f276121fd
    CRC32: 9909ed90
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR20.6.txt (527 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 604459008 字节 (576.46 MB)
    修改日期: 2022-03-25 12:50
    MD5: 2326e07ed28540fc56ba55c386cc36ac
    SHA1: 76105702add5e7524b2f979357225035caa25812
    SHA256: 9399e469555208a76c77480f48e0084bc968052b9cf80ab1472ba7a48661c98b
    CRC32: d26b1841
    NI官方下载和百度网盘下载地址:
    RFmx NR20.6RTE64.txt (552 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 601479168 字节 (573.62 MB)
    修改日期: 2022-03-25 13:07
    MD5: 5c86ecdafca6745a14447796b13a0246
    SHA1: 43f768c65578384e1dc34e492626141fdc49f750
    SHA256: 6fe5ff54e6a38b72179e1cf84c13ce436b40b3908c940706a5cd8c9e7dc5ff07
    CRC32: 3e32a9af
    NI官方下载和百度网盘下载地址:
    RFmx NR20.6RTE32.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 20.6 Readme
    January 2021
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The RFmx NR personality is a highly optimized API for performing physical layer measurements on 5G New Radio (NR) signals. RFmx NR is completely interoperable with all RFmx APIs. It provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is extremely fast and high-quality measurements with minimal software development efforts.
    RFmx NR 20.6 includes the following new features:
    • Support for updates from 3GPP TS 38.101-1/2 v16.4 specification in Adjacent Channel Power measurement to support intra-band contiguous carrier aggregation for FR1 and updates in Channel Measurement Bandwidth for FR2
    • Support for estimation of IQ impairments for receive model in ModAcc
    • Support for compensation of IQ impairments in ModAcc
    • Support for measurement of I/Q timing skew in ModAcc
    • Support for additional results in spectral flatness measurement
    • Support for additional bands: 14, 18, 29, 30, 48, 65, 90, 92, 94
    • Support for PUSCH 8-PSK modulation scheme
    • Support for PXIe-5832
    RFmx NR 20.0 includes the following new features:
    • Support for updates from 3GPP TS 38.104 NR Release 16 specification March 2020
    • Support for PUSCH and PDSCH DMRS for Release 16 as per 3GPP TS 38.211 specification v16.1.0
    • Support for Downlink Test Model 2a and 3.1a for Frequency Range 2
    • Support for 1024 QAM modulation in PDSCH and PUSCH
    • Support for user defined Downlink Multi-user configuration
    • Support for Downlink SS/PBCH EVM in ModAcc measurement for Case A-E
    • Speed improvements in ModAcc measurement
    • Support for speed optimization of the ModAcc measurement by bypassing certain operations
    • ModAcc robustness improvements for low RB allocations in PDSCH/PUSCH
    • Support for Sequential FFT in ACP for measurement bandwidth greater than device instantaneous bandwidth in PXIe-5830/5831/5840/5841
    • Support for measurement bandwidth equal to channel bandwidth in CHP measurement
    • Support for Bandwidth Optimization Enabled mode in composite measurements
    RFmx NR 19.1 includes the following new features:
    • Support for PXIe-5830/5831/5841
    • Support for updates from 3GPP NR Release 15 specification v15.6.0 (June 2019)
    • Support for non-contiguous carrier aggregation
    • Support for power vs time (PVT) measurement for Uplink
    • Support for additional offset channel spacing for carrier aggregation in the ACP measurement
    • Support for auto increment cell id for carrier aggregation
    • Support for PDSCH EVM measurement in the presence of PDCCH
    • Enhanced robustness of ModAcc measurement to analyze filtered waveforms, sequence and group hopping, and impaired signals
    • Added capability to include/exclude DMRS and PTRS EVM in Composite EVM result
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx NR has the following requirements:
    RFmx NR 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx NR dropped support for all 32-bit Windows operating systems. RFmx NR will not install or run on an unsupported OS. Refer to RFmx NR Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx NR dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx NR 20.6 to an unsupported OS. Additionally, after installing RFmx NR 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. To add support for application software installed after installing RFmx NR modify your RFmx NR installation or launch the RFmx NR installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx NR
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1, 2020
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx NR using NI Package Manager. If you do not already have NI software installed, RFmx NR installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx NR » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx NR palette VIs are available from the Functions » Measurement I/O » NI-RFmx » NR palette.
    Documentation for RFmx NR is located at Start » All Programs » National Instruments » RFmx NR » RFmx NR Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx NR HelpHTML/Windows HelpContains primary help content for RFmx NR. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx NR
    • A complete reference for all RFmx NR programming functions and VIs
    RFmx NR 20.6 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx NR examples at Start » All Programs » National Instruments » RFmx NR » RFmx NR Examples.
    The following are the behavior changes in RFmx NR 20.6 from RFmx NR 20.0.
    • Change in the following API names:
      • ModAcc:IQ Origin Offset Estimation Enabled to ModAcc:IQ Impairments:IQ Origin Offset Estimation Enabled
      • ModAcc IQ Impairments Estimation Enabled to ModAcc IQ Mismatch Estimation Enabled
      • ModAcc:IQ Impairments:Estimation Enabled to ModAcc:IQ Impairments:IQ Mismatch Estimation Enabled
    • Changed measurement limits for SEM in-band emission and spectral flatness measurement to the limits defined in 3GPP 38.141 and 3GPP 38.521 specifications
    The following are the behavior changes in RFmx NR 20.0 from RFmx NR 19.1.
    • Updated measurement bandwidth for Uplink FR2 contiguous CA in ACP and CHP
    • Frequency segment definition of Operating Band Unwanted Emission in SEM measurement aligned with section 9.7.4.3.3 of 3GPP TS 38.104 specification v15.9.0/v16.3.0
    • NR SS/PBCH block parameters CRB Offset and Subcarrier Offset in ModAcc measurement are aligned to be 3GPP specification compliant
    The following are the behavior changes in RFmx NR 19.1 from RFmx NR 19.0.
    • Change in default value of Transmit LO Architecture property to LO per Subblock. In this mode:
      • IQ Origin offset result for multicarrier configurations is reported in Subblock IQ Origin Offset Mean result property
      • Quadrature error and IQ Gain Imbalance results are not supported for multicarrier configurations
    • Updated nominal spacing definition for carrier aggregation cases as per Rel 15 Specification June 2019 v 15.6.0. For waveforms compliant to previous Rel 15 releases, use user-defined spacing definition.
    • Composite EVM result does not include the EVM of DMRS and PTRS. You must set ModAcc Composite Results Include DMRS and ModAcc Composite Results Include PTRS properties to True to include the respective EVMs in the Composite EVM result
    • Dropped support for ModAcc EVM Exclusion Period property for Downlink measurement as per the 3GPP NR specification Rel 15 June 2019
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and 5831
    • Obsoleted RFmxNR Analyze (IQ) and RFmxNR Analyze (Spectrum) APIs. Use RFmxNR Analyze (IQ, 1 Wfm) and RFmxNR Analyze (Spectrum, 1 Wfm) APIs instead
    • When you set the Frequency Range property to Range 2 , the new enums, FR2 Category A , FR2 Category B , added to the gNodeB Category property are the only valid enums.
    The following are the behavior changes in RFmx NR 19.0 from RFmx NR 3.0.
    • To load and run a Downlink configuration file saved from RFmx 3.0, the user has to explicitly set value of Downlink Channel Configuration Mode property to User Defined
    You can access the RFmx NR known issues list online at RFmx NR 20.6 Known Issues.
    You can access the RFmx NR bug fix list online at RFmx NR 20.6 Bug Fixes.
    RFmx NR will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2018–2021 National Instruments. All rights reserved.
    377911E-01
    GMT+8, 2026-2-3 05:26
