查看: 1845|回复: 0
[NI软件产品] NI RFmx EV-DO 2022 Q3 Win11 32/64bitEng 1xEV-DO蜂窝测试软件22.5
    15 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2022-8-18 10:26:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    32/64位完整版校验和:
    文件大小: 822134784 字节 (784.05 MB)
    修改日期: 2022-07-23 09:51
    MD5: 826d21add1cecbeeaeebda6c0e4c3b1c
    SHA1: 98433e4aa2d65f1275a0edcc1269676a70494819
    SHA256: 42754d4693e0cef52868951cabb276a1aaa796885f19ccdf6fc7698517a4324f
    CRC32: d7adc01c
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx evdo22.5.txt (544 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    CRC32: d7adc01c
    NI官方下载和百度网盘下载地址:
    RFmx evdo22.5RTE32.txt (576 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    CRC32: d7adc01c
    NI官方下载和百度网盘下载地址:
    RFmx evdo22.5RTE64.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 2022 Q3 Readme
    July 2022
    This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions.
    • RFmx EV-DO Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx EV-DO Manuals: New features, behavior changes, and other documentation
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 2022 Q3 includes the following new feature:
    RFmx EV-DO 21.3 includes the following new feature:
    RFmx EV-DO 20.0 includes the following new features:
    RFmx EV-DO has the following requirements:
    RFmx EV-DO 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx EV-DO no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx EV-DO 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx EV-DO 2022 Q3 to an unsupported OS. Additionally, after installing RFmx EV-DO 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx EV-DO
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx EV-DO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
    Select Start » National Instruments» RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    RFmx EV-DO palette VIs are available from the Functions » Measurement I/O » RFmx » EVDO palette.
    Documentation for RFmx EV-DO is located at Start » National Instruments » RFmx EV-DO Documentation.
    You can access all the installed RFmx EV-DO examples at Start » National Instruments » RFmx EV-DO Examples.
    The following is the behavior change in RFmx EV-DO 20.7 from RFmx EV-DO 20.6.
    The following is the behavior change in RFmx EV-DO 19.1 from RFmx EV-DO 19.0.
    • Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Dropped support for LabVIEW 2015.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    GMT+8, 2026-4-8 23:49
