查看: 1924|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2022 Q3 Win11 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件22.5
    10 小时前
  • 签到天数: 3825 天
     楼主| 发表于 2022-8-18 10:36:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版/运行版,版本号22.5.0
    32/64位完整版校验和:
    文件大小: 1170182144 字节 (1.09 GB)
    修改日期: 2022-07-23 09:53
    MD5: eccdcaf5d4156c67adab2f9ffb3d1c48
    SHA1: 7e5c6d81a2fcd1d6ce4599e921f4d66e92909cee
    SHA256: c1bb0ac7bdf623db0c42ffc86382c96dba3e3deb34431407e153ba88d30f63f1
    CRC32: faa13e4c
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx gsm22.5.txt (544 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 595595264 字节 (568.00 MB)
    修改日期: 2022-07-23 09:56
    MD5: 596ffc0df6ea49ee024e6e39f9b04ceb
    SHA1: eefb8ffadacf807592697127a77bff216c8b98a7
    SHA256: aec1a99bd1c86d4902e1b4627917b129cceb14a9d53e4e78eed5c2a46c7ad885
    CRC32: 8af2003a
    NI官方下载和百度网盘下载地址:
    RFmx gsm22.5RTE32.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 599992320 字节 (572.20 MB)
    修改日期: 2022-07-23 09:54
    MD5: 0dae08b69fc3d362f716408590c94906
    SHA1: 3472f5cbf49b52f58c2f296c0e9ddcd91dfe011f
    SHA256: 774380462835760a4c8ffa81980454661b0f04c710458bda6ccb09aa18adf33d
    CRC32: 8473160a
    NI官方下载和百度网盘下载地址:
    RFmx gsm22.5RTE64.txt (565 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 2022 Q3 Readme
    July 2022
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 2022 Q3 includes the following new feature:
    RFmx GSM 21.3 includes the following new feature:
    RFmx GSM 20.7 includes the following new feature:
    • Support for Custom RBW in case of Modulation and Switching carrier powers.
    RFmx GSM has the following requirements:
    RFmx GSM 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2022 Q3 to an unsupported OS. Additionally, after installing RFmx GSM 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx GSM
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    GMT+8, 2026-3-14 19:28
