查看: 2136|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2022 Q4 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件22.8
    昨天 08:15
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-11-24 11:16:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE+
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版/运行版,版本号22.8.0
    64位完整版校验和:
    文件大小: 1170182144 字节 (1.09 GB)
    修改日期: 2022-07-23 09:53
    MD5: eccdcaf5d4156c67adab2f9ffb3d1c48
    SHA1: 7e5c6d81a2fcd1d6ce4599e921f4d66e92909cee
    SHA256: c1bb0ac7bdf623db0c42ffc86382c96dba3e3deb34431407e153ba88d30f63f1
    CRC32: faa13e4c
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSMEDGE 2022Q4Full.txt (541 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 595595264 字节 (568.00 MB)
    修改日期: 2022-07-23 09:56
    MD5: 596ffc0df6ea49ee024e6e39f9b04ceb
    SHA1: eefb8ffadacf807592697127a77bff216c8b98a7
    SHA256: aec1a99bd1c86d4902e1b4627917b129cceb14a9d53e4e78eed5c2a46c7ad885
    CRC32: 8af2003a
    NI官方下载和百度网盘下载地址:
    RFmx GSMEDGE 2022Q4RTE.txt (565 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 2022 Q4 Readme
    October 2022
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for configurable RBW in PVT measurement.
    RFmx GSM 2022 Q3 includes the following new feature:
    RFmx GSM 21.3 includes the following new feature:
    RFmx GSM has the following requirements:
    RFmx GSM 2022 Q4 supports the following 64-bit operating systems:
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx GSM (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3
    • RFmx GSM drops support for 32-bit user mode.
    The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    GMT+8, 2026-4-16 07:37
