查看: 1807|回复: 0
[LV工具模块] LabVIEW 2013 Third-Party Licensing and Activation Toolkit Win32/64Eng LV2013第三方许可和激活工具包NITPLAT2013
     楼主| 发表于 2022-12-1 14:31:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Third-Party Licensing and Activation工具包
    Third-Party Licensing and Activation工具包可帮助您向LabVIEW应用程序和VI添加许可技术。
    Third-Party Licensing and Activation工具包是LabVIEW的一款附加软件。借助该附加软件,您可以实现许可和激活功能,包括开发许可(为基于VI的API或库提供许可证,供其他LabVIEW开发人员使用)或部署许可(为通过LabVIEW构建的应用程序或可执行文件提供许可证,供用户实现相关功能)。Third-Party Licensing and Activation工具包提供了自动Web激活和手动激活机制。您还可以实施过期评估。
    LabVIEW 2013 Third-Party Licensing & Activation Toolkit
    发布日期:2013/6/15
    包含的版本:2013完整版
    受支持的操作系统
    Windows 10
    Windows 8.1
    Windows 7
    文件大小: 54550816 字节 (52.02 MB)
    修改日期: 2022-03-25 06:10
    MD5: d7304b870e2c78723bee0b3f85841d09(秒传)
    SHA1: 9a90cbbf12eae0cfa58acdd9e05ae3e5f7a90af1
    SHA256: a0a0657141da4af0dba2a93b808030c89eb8706022d69e371f3de1f072520887
    CRC32: 3ac0bc55
    请注册登录视觉论坛账号,购买附件查看下载地址
    NITPLAT2013.txt (527 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2013 Third Party Licensing & Activation Toolkit Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW Third Party Licensing & Activation Toolkit, including installation instructions, new features, a partial list of bugs fixed for LabVIEW 2013 Third Party Licensing & Activation Toolkit, and known issues.
    Upgrade Issues
    The Third Party Licensing & Activation Toolkit enables you to license the add-ons that you create with LabVIEW. Users of a licensed add-on must evaluate or activate the add-on according to the activation methods you allow.
    In addition to the system requirements for the LabVIEW Development System, the Third Party Licensing & Activation Toolkit has the following requirements:
    • LabVIEW 2010, 2011, 2012, or 2013 Base, Full, or Professional Development System
    • At least 50 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    You can download and install Third Party Licensing & Activation Toolkit from LabVIEW Tools Network. For more information about the toolkit, visit the Third Party Licensing & Activation Toolkit community.
    Third Party Licensing & Activation Toolkit Updates and Notifications
    The Third Party Licensing & Activation Toolkit includes various enhancements to the user interface and features. Refer to the Bug Fixes section of this readme for more information on the enhancements and the Finding Examples section for information on accessing examples of the demonstrated features.
    Upgrade Issues
    If you use the Application Builder to build installers for add-ons, update the executable that automatically runs and calls RegisterAddon.exe when an installer runs. National Instruments recommends that you call RegisterAddon.exe with the following command line: RegisterAddon.exe -- -s -l path_to_lvlib. The -s parameter enforces a more secure form of licensing when customers install the add-on for use with LabVIEW 2011 SP1 and later. For each installer, update the VI that serves as source for the executable that calls RegisterAddon.exe, rebuild the executable, and then rebuild the installer.
    Refer to the Toolkits»Third Party Licensing & Activation Toolkit»Licensing a Development Add-on»Adding Standard Licensing»Final Step: Package the Add-on for Distribution topic on the Contents tab of the LabVIEW Help for more information about building and distributing add-on installers.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Third Party Licensing & Activation Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Third Party Licensing & Activation Toolkit. This is not an exhaustive list of issues fixed in the current version of the Third Party Licensing & Activation Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    306555Usability improvements to the interface of the Third Party Add-on Activation page.
    338118Licensing an lvlib containing other lvlibs and VIs only protects VIs in the top-level lvlib.
    388808LVClasses and XControls under libraries do not get licensed using the Third Party Licensing & Activation Toolkit.
    393301Upgraded the Concept Software DLLs to 4.6.0.7.
    397588Save For Previous prompts for password for the Remove Licensing VI.
    Refer to the Toolkits»Third Party Licensing & Activation Toolkit book on the Contents tab in the LabVIEW Help for more information about the Third Party Licensing & Activation Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Third Party Licensing & Activation Toolkit are located in the labview\examples\addonlicensing directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    NI LabVIEW Third Party Licensing & Activation Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Third Party Licensing & Activation Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Third Party Licensing & Activation Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2010–2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 07:37
