查看: 1829|回复: 0
[NI软件产品] NI Spectral Measurements Toolkit 17.0.0 Win32/64Eng NI频谱测量工具包SMT17.0.0
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-12-1 16:23:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Spectral Measurements工具包
    Spectral Measurements工具包为时域和频域信号提供频谱分析和频谱测量工具。
    Spectral Measurements工具包是LabVIEW、C和.NET的一款附加软件,提供了用于频谱分析和频谱测量的功能和工具。借助该工具包,您可以对时域数据执行连续(实时)或块(无损)缩放FFT处理,以计算所需的结果,例如原始FFT、幅度谱、功率谱、互谱、频率响应和频谱图。使用Spectral Measurements工具包,您可以对处理后的数据,比如频带功率、相邻信道功率(ACP)、占用带宽(OBW)、峰值搜索等执行频谱测量。Spectral Measurements工具包还提供了高级处理参数,包括分辨率带宽(RBW)、加窗、滤波、单位转换和各种频谱均值法。
    发布日期:2017/7/31
    包含的版本:17.0.0
    受支持的操作系统
    Windows 10 32-bit
    Windows 8.1 64-bit
    Windows 8.1 32-bit
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows Server 2012 R2 64-bit
    文件大小: 1048222616 字节 (999.66 MB)
    修改日期: 2022-03-25 17:09
    MD5: 8a6514b89351bed54895baecb5d80141(官方正确)
    SHA1: de29f0c017ac752a6247ef098b59fcb0d90bbb87
    SHA256: a12ea3046d4c35d370122d8841d577e5d9c4202824162a183a5f32b25b0525bd
    CRC32: 02fbbfee
    请注册登录视觉论坛账号,购买附件查看下载地址
    SMT17.0.0.txt (506 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Spectral Measurements Toolkit 17.0 Readme
    June 2017
    This file contains important information about the NI Spectral Measurements Toolkit and is organized into the following sections:
    Accessing VIs and Functions
    Toolkit Version Naming Changes
    Uninstalling/Modifying NI Spectral Measurements Toolkit
    NI Spectral Measurements Toolkit 17.0 adds support for LabVIEW 2017 (32- and 64-bit)
    NI Spectral Measurements Toolkit 16.0 adds support for LabVIEW 2016 (32- and 64-bit)
    NI Spectral Measurements Toolkit 15.0 adds support for LabVIEW 2015 (32- and 64-bit)
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    NI Spectral Measurements Toolkit 17.0 supports the following operating systems:
    Note  NI Spectral Measurements Toolkit 17.0 and later does not support Windows Server non-R2 editions.
    NI Spectral Measurements Toolkit 17.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum Requirements
    Recommended System
    • Processor—Intel Core i5 or equivalent
    • RAM—4 GB
    • If your application runs on an RT target, NI recommends that you have at least 128 MB of RAM
    Note  The SMT run-time Engine must be installed on systems running applications built using the NI Spectral Measurements Toolkit and LabWindows™/CVI™. The SMT run-time installer is available on the NI Spectral Measurements Toolkit CD in the NISMTCVIRTE folder (setup.exe).
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI Spectral Measurements Toolkit. To add support for ADEs installed after installing NI Spectral Measurements Toolkit, modify your NI Spectral Measurements Toolkit installation or launch the NI Spectral Measurements Toolkit installer again.
    • NI LabVIEW 2014 SP1, 2015 SP1, 2016, or 2017
    • NI LabVIEW Real-Time Module 2014 SP1, 2015 SP1, 2016, or 2017
    • LabWindows/CVI 2013 or later
      • \LabVIEW
    ItemInstalled Location
    VIs\vi.lib\addons\Spectral Measurements Toolset
    Examples\examples\Spectral Measurements Toolset
    Documentation for NI Spectral Measurements Toolkit 17.0 is located at Start»All Programs»National Instruments»Spectral Measurements Toolkit»Spectral Measurements Toolkit Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Spectral Measurements Toolkit LabVIEW HelpHTML/Windows HelpContains primary help content for NI Spectral Measurements Toolkit products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI Spectral Measurements Toolkit
    • A complete reference for all NI Spectral Measurements Toolkit programming VIs
    NI Spectral Measurements Toolkit Function Reference HelpHTML/Windows HelpContains reference information about the Spectral Measurements LabWindows/CVI functions.
    NI Spectral Measurements Toolkit ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI Spectral Measurements Toolkit palette VIs are available from the Functions»RF Communications»Spectral Measurements Toolkit palette.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI Spectral Measurements Toolkit examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI Spectral Measurement Toolkit examples) and their descriptions:
    • Click the Browse tab to locate spectral measurement examples by task at Toolkit and Modules»Spectral Measurements or by directory structure at Spectral Measurements Toolset.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Spectral" to locate all NI Spectral Measurement Toolkit examples.
    You can also access all the installed NI Spectral Measurement Toolkit examples for LabVIEW at Start»All Programs»National Instruments»Spectral Measurements Toolkit»Spectral Measurements Toolkit Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the NI Spectral Measurements Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI Spectral Measurements Toolkit 17.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI Spectral Measurements Toolkit drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI Spectral Measurements Toolkit 17.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Spectral Measurements Toolkit 17.0 to an unsupported OS. Additionally, after installing NI Spectral Measurements Toolkit 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI Spectral Measurements Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: . For example, NI Spectral Measurements Toolkit 17.0 is the version released with LabVIEW 2017. The last version released under the old numbering scheme is NI Spectral Measurements Toolkit 2.7. The first version released under the new numbering scheme is NI Spectral Measurements Toolkit 15.0.
    • Select NI LabVIEW Spectral Measurements 17.0 from the dialog box that appears.
      Note  To uninstall or modify the NI Spectral Measurements Toolkit for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit 17.0 from the dialog box that appears.
      Note  To uninstall or modify the NI Spectral Measurements Toolkit Runtime for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit Runtime 17.0 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    The following are the behavior changes in NI Spectral Measurement Toolkit 15.0 from NI Spectral Measurement Toolkit 2.7:
    • The VIs present in the directory, /addons/Spectral Measurements Toolset/LVSupport/SMT niScope Utilities/SMT niScope Dependent are no longer in niSMT.lvlib.
    • The following VIs present in the directory, /addons/Spectral Measurements Toolset are no longer in niSMT.lvlib:
      • Config DDC band.vi
      • Analog SW triggered Read.vi
      • Set 5620 Reference Clock.vi
      • RFSA Segmented Span Configuration.vi
      • SMT Config niDaq for Cont Zoom.vi
      • SMT Config niDaq for Spectrum.vi
      • RFSA Segmented Span Application.vi
    Note  The location of these VIs on the disk has not changed. Applications using the VIs present in this directory need to be manually relinked.
    You can access the software and documentation known issues list online. Refer to the NI Spectral Measurements Toolkit 17.0 Known Issues at ni.com for an up-to-date list of known issues in NI Spectral Measurements Toolkit 17.0.
    The following items are the IDs and titles of a subset of issues fixed in the NI Spectral Measurements Toolkit. This is not an exhaustive list of issues fixed in the current version of the NI Spectral Measurements Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.4 from NI Spectral Measurements Toolkit 2.6.3.
    374121Fixed an issue in which the users were unable to install the NI Spectral Measurements Toolkit on LabVIEW 2012.
    404823Fixed an issue where multiple shortcuts to documents were present in the Start Menu folder for NI Spectral Measurements Toolkit.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.3 from NI Spectral Measurements Toolkit 2.6.2.
    320267Fixed an issue where the NI license manager was unable to check out NI Spectral Measurements Toolkit license from certain packages in a volume license file.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.2 from NI Spectral Measurements Toolkit 2.6.1.
    309228Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Spectral Measurement Toolkit dependencies.
    307793Fixed an issue where the SMT filter spectrum function clears all the values of the spectrumInfo struct.
    © 2001–2017 National Instruments. All rights reserved.
    375432C-01
    GMT+8, 2026-4-15 13:41
