TA的每日心情 | 无聊 3 小时前 |
签到天数: 3860 天 连续签到: 53 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-22 14:46:03
来自:广东省东莞市 电信
康耐视Cognex IN-SIGHT OPC SERVER 5.5
The In-Sight OPC Server provides access to In-Sight spreadsheet cell data from OPC clients based on versions 1.0, 2.0 or 3.0 of the OPC Specification. In order for In-Sight cell data to be visible to OPC clients, "OPC tags" are inserted into spreadsheet cells that contain data on an In-Sight vision system. Once a tag has been applied to a cell, the In-Sight OPC Server is then configured to publish the tag and its associated value so that OPC clients can access it.
You must be logged on as a user with full administrative privileges in order to install the In-Sight OPC Server and you must disable User Account Control (UAC) before installing the In-Sight OPC Server. For instructions on how to disable UAC, do the following:
Windows 7/Windows Sever 2008 R2:
Click Start > Help and Support.
In the search box, type: Turn off UAC
Press ENTER.
View the first search result topic entitled "Turn User Account Control on or off".
Windows 10: You must disable UAC from Registry Editor by manually changing the value. (Note: Disabling UAC from the Control Panel > User Accounts will not allow you to install the In-Sight OPC Server on Windows 10.)
Press the Windows key + R on your keyboard. The Run dialog opens.
Type regedit and click OK. Registry Editor opens.
Select HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > Current Version > Policies > System.
Right-click on EnableLUA, and select Modify. The Edit DWORD Value dialog opens.
Change the Value data to 0.
Click OK to close the dialog.
Restart your PC. Now you can install the In-Sight OPC Server.
After installation, you may re-enable UAC; however, in order to uninstall the In-Sight OPC Server you will need to temporarily disable it again.
文件类型: .exe
文件大小: 32.9MB
版本: 5.5.0
发布日期: 2017/10/13
文件名: Cognex In-Sight OPC Server 5.5.0.exe
文件大小: 34541000 字节 (32.94 MB)
修改日期: 2021-02-14 23:05
版本: 5.5.0.1019
MD5: b4bd980ae5093e99b20bf47f9cef8346
SHA1: af5cf4d74bfabb4b5727b24af89d92de042eef3d
SHA256: e78e10158b3437ed851e1d49bd461cf5561f88e132c0ee06760e8b497d876e80
CRC32: 5353767c
康耐视官方下载:
通过百度网盘分享的文件:Cognex In-Sight OPC Server 5.5.0.exe
链接:https://pan.baidu.com/s/16MaqZB6fU8Tn1PiHW6gAiA
--来自百度网盘超级会员V7的分享 |
