查看: 1188|回复: 1
[Cognex] 康耐视Cognex IN-SIGHT EXPLORER 6.5.1
    3 小时前
  • 签到天数: 3860 天
    连续签到: 53 天
     楼主| 发表于 2024-11-25 15:46:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    In-Sight Explorer 6.5.1 is a follow-on release to 6.5.0.
    Changes from In-Sight Explorer 6.5.1 firmware 20 to firmware 22 *Updated 4-Nov-2024*
    Fixed a case where WebHMI connection was broken
    In-Sight Explorer 6.5.1 introduces the following new feature:
    ValidateIDData: updated GS1 data validation by supporting new application identifiers (AIs) to August 2024 version. This includes AIs 716, 7041, 7250-7259, 4330-4333, 7241, 7242, and 8030. Further enhanced AIs 8013 and 8014.
    In addition to the new feature, several bugs were fixed in this release including:
    Audit messaging: WebHMI user and host source are now correctly logged when modifying the EditCompositeRegion function.
    Audit messaging: Unsuccessful login attempts are now logged.
    Fixed a firmware memory leak that occurs when opening and closing WebHMI connections.
    Resolved a 9902L issue where connections could be dropped due to noise interference.
    Discrete outputs: Fixed a condition where output pulse widths were occasionally shorter than expected. This was observed on fast-triggering applications, or when multiple output signals occurred simultaneously.
    Fixed a fatal condition that could occur during the bootup process of an In-Sight 8500 series vision system.
    ReadIDMax omni-postal (PLANET): improved decoding for 14-digit Postnet codes, resolving certain no-read conditions.
    Cognex Network Server documentation: added instructions on how to set up a remote datastore for Audit Logging. For more information, see the Cognex Network Server documentation.
    Compatible firmware
    In-Sight Explorer 6.5.1 includes firmware versions for the following models:
    (1) In-Sight firmware 6.05.01
    In-Sight 7000 Gen2 series vision systems
    In-Sight 8000 series vision systems
    In-Sight 9000 Series Vision System
    In-Sight Advantage Engine
    (2) In-Sight firmware 5.09.02
    In-Sight 5705 and 5705C vision systems
    (3) In-Sight firmware 4.10.05 PR1
    In-Sight Micro 1000 series vision systems
    In-Sight 5000 series vision systems (except In-Sight 5705 and 5705C vision systems)
    In-Sight 7000 series vision systems (except In-Sight 7000 Gen2 series vision systems)
    If you are using TruCheck / SBG, please use the latest In-Sight Explorer 6.3.x.
    Windows system requirements
    In-Sight Explorer 6.5.1 supports the following Windows operating systems:
    Microsoft Windows 10 Professional (64-bit)
    Microsoft Windows Server 2016
    If you are using Windows 7 (64-bit), please use In-Sight Explorer 5.9.2.
    文件类型: .exe
    文件大小: 1.0GB
    版本: 6.5.1
    发布日期: 2024/10/14
    文件名: Cognex In-Sight Software 6.5.1.exe
    文件大小: 1077910896 字节 (1.00 GB)
    修改日期: 2024-11-05 04:54
    版本: 6.5.1.41
    MD5: 79cd8ab6cf1b96dc4abf5ba89fdc3604
    SHA1: ed9979bb895a5154b069cb9fa65a48f335f8ece5
    SHA256: 739e42d261de2ac270ba55432ae84d46d283c942d4c16f7f1028e06164854155
    CRC32: 1752e5da
    康耐视官方下载:
    通过百度网盘分享的文件:Cognex In-Sight Software 6.5.1.exe
    链接:https://pan.baidu.com/s/1NAADE1FVH1JSVUTGbHJszw
    --来自百度网盘超级会员V7的分享
  • 签到天数: 2 天
    发表于 2025-8-29 08:32:16 | 显示全部楼层 来自:江苏省苏州市 电信
    GMT+8, 2026-4-18 13:29
