查看: 881|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for IF Digitizers 2025 Q2 Win11 32/64bitEng LabVIEW IF数字化仪仪器设计库25.3.0
    6 小时前
  • 签到天数: 3851 天
    连续签到: 44 天
     楼主| 发表于 2025-5-17 10:22:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Instrument Design Libraries for IF Digitizers提供的仪器功能可帮助您在PXIe-5624R IF数字化仪上对FPGA进行编程。
    LabVIEW Instrument Design Libraries for IF Digitizers是一款旨在提供软件库的驱动软件。这些软件库通过为主机和FPGA提供通用的仪器功能(例如硬件配置和数据通信)来简化与模块上供应商代码的连接。LabVIEW Instrument Design Libraries for IF Digitizers还包括了范例项目和模板。
    发布日期:2025/4/9
    包含的版本:2025 Q2完整版,版本号25.3.0
    受支持的操作系统
    Windows Server 2025
    语言:英文English
    程序位数:32/64位
    文件大小: 1309329408 字节 (1.22 GB)
    修改日期: 2025-04-12 15:23
    MD5: 7c05a7de73014b46a8ca937b1c5083b8
    SHA1: 0463c642fb1cf7ea0d15c509b23a297987c30d71
    SHA256: f63804bb4841baed1b5be6631ec5ec85e25fa35f9eb8088574922230259ce78d
    CRC32: 8dd3585b
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    IF Digitizers2025Q2.txt (592 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q2版本未更新自述文件,参考2023Q1版
    NI LabVIEW Instrument Design Libraries for IF Digitizers 2023 Q1 Readme
    March 2023
    This file contains installation instructions and compatibility information for NI LabVIEW Instrument Design Libraries for IF Digitizers 2023 Q1.
    • NI LabVIEW Instrument Design Libraries for IF Digitizers Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI LabVIEW Instrument Design Libraries for IF Digitizers Documentation: New features, behavior changes, and other documentation
    Accessing VIs and Functions
    Accessing LabVIEW Sample Projects
    NI LabVIEW Instrument Design Libraries for IF Digitizers 2023 Q1 adds support for LabVIEW 2022 and LabVIEW 2023.
    The Instrument Design Libraries support the PXIe-5624 IF digitizer.
    System RequirementsMinimum System Requirements (Systems Not Compiling FPGA Images Locally)
    • Processor—Intel Pentium 4 or equivalent
    • RAM—4 GB
    • A supported 64-bit operating system, with all available critical updates and service packs
    Minimum System Requirements (Systems Compiling FPGA Images Locally)
    • RAM—8 GB
    Recommended System
    • Processor—Intel i7 or equivalent
    • RAM—16 GB
    Note  Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target. Additional RAM beyond the recommended system requirements may be necessary to compile multiple FPGA images concurrently. Refer to the LabVIEW FPGA Module Readme for more information about determining your memory needs for FPGA VI compilation.
    Note  You should install LabVIEW and LabVIEW FPGA (recommended) before installing the Instrument Design Libraries. To add support for ADEs installed after installing the Instrument Design Libraries, modify your Instrument Design Libraries installation or relaunch the Instrument Design Libraries installer.
    • LabVIEW 2022 (32-bit or 64-bit) or LabVIEW 2023 (32-bit or 64-bit)
    • (Recommended) LabVIEW 2022 or 2023 FPGA Module
    When installing NI LabVIEW Instrument Design Libraries for IF Digitizers, the "NI LabVIEW Instrument Design Libraries for IF Digitizers for LabVIEW" package will be recommended if you have already installed LabVIEW 2023 or later and installs to the LVAddons directory. This package supports applications using NI LabVIEW Instrument Design Libraries for IF Digitizers with LabVIEW 2023 or later.
    NI LabVIEW Instrument Design Libraries for IF Digitizers 2023 Q1 supports the following operating systems:
    • Windows 11, 10
    Note  In 2019, NI LabVIEW Instrument Design Libraries for IF Digitizers dropped support for all 32-bit Windows operating systems. NI LabVIEW Instrument Design Libraries for IF Digitizers will not install or run on an unsupported OS. Refer to NI LabVIEW Instrument Design Libraries for IF Digitizers Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    is an alias for the following National Instruments file folder location: Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
    is an alias for the following National Instruments file folder location: Program Files\NI
    Files
    Installed Location (LabVIEW 2022)
    Installed Location (LabVIEW 2023 or later)
    IF Digitizer Instrument Design Libraries\LabVIEW 2022\instr.lib\niIFDig\LVAddons\niebidl\1\instr.lib\niIFDig
    Common Instrument Design Libraries\LabVIEW 2022\instr.lib\_nInstr\LVAddons\niidl\1\instr.lib\_nInstr
    Calibration Support for LabVIEW\LabVIEW 2022\instr.lib\niIFDig\Calibration\LVAddons\niebidl\1\instr.lib\niIFDig\Calibration
    Documentation for the Instrument Design Libraries is located at Start»National Instruments»IF Digitizers Documentation. The documentation set is composed of the following documents. You can find hardware documentation for the PXIe-5624 on ni.com/manuals.
    Document
    Format
    Description
    NI IF Digitizers HelpHTML/Windows HelpContains primary help content for NI IF digitizer products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI IF digitizers
    • Hardware device information
    • Programming overviews
    NI LabVIEW Instrument Design Libraries for IF Digitizers ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    The Instrument Design Libraries palette VIs are available on the host from the Functions»FPGA Interface»Software-Designed Instruments»IF Digitizers palette. For FPGA VIs, palettes specific to the FPGA target are available from the Functions palette.
    To access the LabVIEW sample projects and templates from the Create Project dialog box, select Sample Projects»IF Digitizers in the left pane and navigate to the project that best matches your application requirements.
    © 2014–2023 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-9 14:32
