查看: 7|回复: 0
[NI软件产品] LabVIEW 2026 Q1 FPGA Module Xilinx Compilation Tools Linux64En LV2026Q1 FPGA编译工具(Vivado 2021.1)
    10 小时前
  • 签到天数: 3841 天
    连续签到: 34 天
     楼主| 发表于 1 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW 2026 Q1 FPGA Compilation Tool for Vivado 2021.1
    发布日期:2026/1/28
    包含的版本:2026 Q1完整版,版本号26.1.0
    支持:Vivado 2021.1
    Linux
    校验和
    文件大小: 217069 字节 (211.98 KB)
    修改日期: 2026-02-08 10:24
    MD5: 454ef8962c200a3b025c7b9e2c451030
    SHA1: ac46448ce50abf2f9ce6c78b2893ddf22cad5c5a
    SHA256: a6539509ace2ce8269b85b7bc56cdeea779882a754dacadb772f65479e4b53bf
    SHA512: b12ce14f16238f3fc23f4f24dabfa9efe42cf6db715853a2f51b85d85d967b004980d4d5333e2807aa65cc8f4eb574e45d1c5b7f19e7f9163ba133f2181f6309
    百度网盘下载和NI官方下载地址:
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    FPGA Compilation Tool for Vivado 2021.1 2026Q1 Linux.txt (746 Bytes, 下载次数: 0, 售价: 10 圆)
    2026Q1版未更新自述文件,参考2020版
    LabVIEW 2020 FPGA Module Xilinx Compilation Tools for Linux Readme
    March 2020
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2019.1 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2019.1 has the following system requirements:
      • Red Hat Enterprise Linux 7.4/7.5/7.6 (64-bit)
      • CentOS 7.4/7.5/7.6 (64-bit)
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    • Red Hat Enterprise Linux 6.5 (64-bit)
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux. Devices that are compatible with the FPGA Module (64-bit) are in bold.
    Use the Xilinx Compilation Tool for Vivado 2019.1 to compile FPGA VIs for the following devices:
    • cRIO-903x/904x/905x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS III
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-576x/577x/5785/6593/782xR/7846/7856/7857/7858/798x
    • PXIe-5163R/5164R/517xR/5624R/5745/576x/577x/5785/5840R/659x/782xR/784x/785x/786x/786xR/7902R/791x/793xR/797xR/798x/799x
    • roboRIO
    • sbRIO-9603/9608/9609/9628/9629/9638/9651/96x7
    • USB-784xR/785xR
    • USRP-RIO devices
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • IC-312x
    • NI-915x
    • NI CVS-145x/145xRT
    • PCIe-7841R/7842R/7851R/7852R/1473R/8237R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Use mount to mount the compilation tools installer.
    • If the media type is DVD, change the current directory to the mount point.
      If the media type is USB, change the current directory to mount point/Linux/Vivado2019_1 or mount point/Linux/ISE14_7, depending on which tool you want to install.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2020 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    /usr/local/natinst/nifpgacompileworker/doc
    374740L-01
    GMT+8, 2026-3-30 18:41
