查看: 11486|回复: 0
[LV工具模块] LabVIEW Report Generation Toolkit for Microsoft Office 2011 LV报表工具包RGT2011
发表于 2013-5-9 20:46:55 | 显示全部楼层 |阅读模式
LabVIEW Report Generation Toolkit for Microsoft Office 2011 for LabVIEW 2011 报表工具包RGT2011适用LabVIEW2011
RGT报表生成工具包,从LabVIEW2014版开始,有64位版本。在LabVIEW2014-LabVIEW2015版中(含相应的SP1版本),32位的标准安装包中,集成了RGT工具包,但是64位中没有集成该工具包,需要单独下载安装。从LabVIEW2016版开始,则在32位版本、64位版本中,都集成了RGT工具包可选择安装,不需要另外安装。(这里限标准的安装包,即大小一般1-2GB大小的安装文件,各种套件可能不包含RGT的情况。)
June 2011 Version 11.0.0
LabVIEW2009-LabVIEW2013SP1版本的RGT工具包,都是单独安装的。从LabVIEW2014版后,在LV中集成RGT工具包,不需要再单独下载安装。
The computer you are using must meet the following minimum system requirements to run the Report Generation Toolkit:
Windows 7 (32-bit and 64-bit)
Windows Vista (32-bit and 64-bit)
Windows XP Service Pack 2 or later (32-bit)
40 MB of hard drive space
LabVIEW 2011 Base, Full, or Professional Development System (32-bit)
Microsoft Office 2010/2007/2003/XP
Note:  You must have both Microsoft Word and Microsoft Excel installed before installing the Report Generation Toolkit.
请注册视觉论坛用户,登录后购买附件下载查看
RGT2011.txt (654 Bytes, 下载次数: 38, 售价: 10 圆)
LabVIEW 2011 Report Generation Toolkit for Microsoft Office Readme
Version 11.0.0
June 2011
This file contains information to introduce you to the LabVIEW 2011 Report Generation Toolkit for Microsoft Office. The file contains the following information that you need to understand.
Refer to the National Instruments Web site for the latest information about the Report Generation Toolkit. Refer to the LabVIEW Help for more information about using the Report Generation Toolkit.
  • Windows XP Service Pack 2 or later (32-bit)
  • 40 MB of hard drive space
  • LabVIEW 2011 Base, Full, or Professional Development System (32-bit)
  • Microsoft Office 2010/2007/2003/XP
You can install all of your LabVIEW products—including the Report Generation Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the Report Generation Toolkit along with activation instructions in the following locations:
  • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 Report Generation Toolkit.
IDKnown Issue
227535When the Word Update Graph VI uses templates with the file name extension *.docx from Office 2007 or Office 2010, an error occurs. As a workaround save the template with the file name extension *.doc.
The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 Report Generation Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the LabVIEW 2011 Report Generation Toolkit.
248732LabVIEW 2010 Report Generation Toolkit for Microsoft Office has a licensing bug that only affects users that are part of a Volume License Agreement (VLA).
Important Information
QQ|LabVIEW视觉
GMT+8, 2026-4-8 13:16
