查看: 4974|回复: 2
[LV工具模块] LabVIEW 2013 Adaptive Filter Toolkit Win32Eng LabVIEW自适应滤波器工具包2013版
    6 小时前
  • 签到天数: 3858 天
    连续签到: 51 天
    发表于 2020-11-7 23:53:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    算法包括: LMS, 归一化LMS, 漏溢式LMS, 快速LMS, sign LMS, RLS和QR-RLS
    用于主动噪音/振动控制的X滤波LMS和归一化X滤波LMS
    范例包括: 自适应噪声/回声消除, 自适应系统辨识, LPC
    用于定点LMS自适应滤波器的仿真和NI LabVIEW FPGA代码自动生成
    2013
    文件大小: 84411168 字节 (80.50 MB)
    修改日期: 2013-06-28 23:01
    MD5: 01309651752fa49e65c2a84bb918f2d4(重复下载一致)
    SHA1: 6a3d9da998ab585c0d970b9e37a74fa485fbb5e0
    SHA256: 40f3da557cdb076fc663b3d02f1ce6aeccbe8bdffb796fd4bb89f7d6c1257903
    CRC32: 80e94dd0
    百度网盘和NI官方下载下载:
    AFTK2013.txt (680 Bytes, 下载次数: 5, 售价: 10 圆)
    LabVIEW 2013 Adaptive Filter Toolkit Readme
    Version 13.0.0
    June 2013
    The LabVIEW 2013 Adaptive Filter Toolkit updates the Adaptive Filter Toolkit 2012 to support LabVIEW 2013. This release is a maintenance release.
    The Adaptive Filter Toolkit includes tools for designing, analyzing, and simulating adaptive filters, including fixed-point adaptive filters. This file contains the following information about the Adaptive Filter Toolkit.
    An adaptive filter is a computational device that iteratively models the relationship between the input and output signals of the filter. An adaptive filter self-adjusts the filter coefficients according to an adaptive algorithm. You can use the Adaptive Filter Toolkit to create adaptive filters with the following adaptive algorithms:
    • Least mean squares (LMS) and the variants, such as normalized LMS, leaky LMS, normalized leaky LMS, sign LMS, and fast block LMS
    • Filtered-x LMS and normalized filtered-x LMS
    • Recursive least squares (RLS) and QR decomposition-based RLS (QR-RLS)
    You can apply the adaptive filters that you create to different applications, such as adaptive noise cancellation, adaptive echo cancellation, system identification, and so on. You also can create and implement fixed-point adaptive filters on National Instruments FPGA targets.
    In addition to the system requirements for the LabVIEW Development System, the Adaptive Filter Toolkit has the following requirements:
    • LabVIEW 2013 Full or Professional Development System (32-bit)
    • At least 50 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    Note  If you want to use the Adaptive Filter Toolkit to generate LabVIEW FPGA code for a fixed-point adaptive filter, you must install the LabVIEW FPGA Module on the host computer.
    You can install all of your LabVIEW products—including the Adaptive Filter Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Adaptive Filter Toolkit Updates and Notifications
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Adaptive Filter Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Adaptive Filter Toolkit.
    Select Help»Find Examples from LabVIEW to lauch the NI Example Finder. Navigate to the Toolkits and Modules»Adaptive Filters folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Adaptive Filter Toolkit in the labview\examples\Adaptive Filters directory.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Adaptive Filter Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Adaptive Filter Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Adaptive Filter Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2013 National Instruments. All rights reserved.
    发表于 2024-3-4 13:45:16 | 显示全部楼层 来自:山东省济南市 山东大学
    6 小时前
  • 签到天数: 3858 天
    连续签到: 51 天
     楼主| 发表于 2024-3-4 15:41:47 | 显示全部楼层 来自:广东省东莞市 电信
    daisy 发表于 2024-3-4 13:45
    请问如何下载呀
    充值赞助页面扫码付款,备注自己的论坛账号,手动充值后可自行购买txt附件查看下载地址
    机器视觉论坛赞助充值方式
    http://visionbbs.com/thread-21377-1-1.html
    (出处: 石鑫华视觉论坛)
    GMT+8, 2026-4-16 14:14
