查看: 1607|回复: 0
[RTE运行引擎] NI RFmx for Bluetooth Test 21.5 Runtime x64Win10 64bitEng RFmx蓝牙测试NIRFmxBluetooth21.5运行版64位
 楼主| 发表于 2022-7-6 16:15:38 | 显示全部楼层 |阅读模式
发布日期:2022/1/27
包含的版本:21.5运行版
校验和
文件大小: 637618176 字节 (608.08 MB)
修改日期: 2022-03-25 08:46
MD5: e324bdd9608de88e89ac8d427b5a5763
SHA1: a4c70ace350213418c25f7d0fa95fcf3964ddc91
SHA256: 57c658ea074fcfe1dd443fd5c1997b99e3b67dac51cf0ff1ad8b073d998f3775
CRC32: 0dd57afc
注册登录视觉论坛账号,购买附件查看下载地址
RFmxBT21.5RTE64.txt (580 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx for Bluetooth® Test 21.5 Readme
January 2022
This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions.
  • RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
  • RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
RFmx for Bluetooth® Test supports the following features:
  • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.2, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
  • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.2.
  • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
  • Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
  • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
RFmx for Bluetooth® Test 21.3 includes the following new features:
  • Support for DEVM magnitude and phase error results in ModAcc measurement
RFmx for Bluetooth® Test 20.0 includes the following new features:
  • Support to configure RFInstr properties in the context of signal configuration
  • Support for Demodulated Bit Trace in ModAcc measurement
RFmx for Bluetooth® Test 19.1 includes the following new features:
  • Support for angle of departure transmitter tests on low energy physical layer signals
Vector Signal Analyzers
  • PXIe-5668
  • PXIe-5668 with PXIe-5698
Vector Signal Transceivers
  • PXIe-5646
  • PXIe-5840
  • PXIe-5841
  • PXIe-5820
  • PXIe-5841
  • PXIe-5841 with PXIe-5655
RFmx for Bluetooth® Test has the following requirements:
RFmx for Bluetooth® Test 21.5 supports the following 64-bit operating systems:
Note    RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 21.5 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 21.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
RFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support.
Versions Supported by RFmx for Bluetooth® Test
If you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
Download the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
  • Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
Item
Installed Location
Import Library files (64-bit)
Select Start » National Instruments » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
RFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Bluetooth palette.
Documentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx Bluetooth Documentation. The documentation set is composed of the following documents.
Document
Format
Description
RFmx for Bluetooth® Test HelpHTML/Windows HelpContains primary help content for RFmx for Bluetooth® Test. This help file is an HTML version of a traditional user manual that includes the following information:
  • An introduction to RFmx for Bluetooth® Test
  • A complete reference for all RFmx for Bluetooth® Test programming functions and VIs
RFmx for Bluetooth® Test 21.5 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
You can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx Bluetooth Examples.
The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7.
  • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
The following are the behavior changes in RFmx for Bluetooth® Test 20.7 from RFmx for Bluetooth® Test 20.6.
The following items are behavior changes in RFmx for Bluetooth® Test 19.1 from RFmx for Bluetooth® Test 19.0.
  • Obsoleted RFmxBT Analyze (IQ) API. Use RFmxBT Analyze (IQ, 1 Wfm) API instead
  • A warning is thrown if the measurement fails to detect start of the packet when you set the Burst Sync Type property to Preamble
The following items are behavior changes in RFmx for Bluetooth® Test 19.0 from RFmx for Bluetooth® Test 3.0.
377890J-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 15:31
