查看: 4177|回复: 0
[NI软件产品] NI Spectral Measurements Toolkit 2.6.3 Win32/64Eng NI频谱测量工具包SMT2.6.3
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-12-1 16:10:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Spectral Measurements工具包
    Spectral Measurements工具包为时域和频域信号提供频谱分析和频谱测量工具。
    Spectral Measurements工具包是LabVIEW、C和.NET的一款附加软件,提供了用于频谱分析和频谱测量的功能和工具。借助该工具包,您可以对时域数据执行连续(实时)或块(无损)缩放FFT处理,以计算所需的结果,例如原始FFT、幅度谱、功率谱、互谱、频率响应和频谱图。使用Spectral Measurements工具包,您可以对处理后的数据,比如频带功率、相邻信道功率(ACP)、占用带宽(OBW)、峰值搜索等执行频谱测量。Spectral Measurements工具包还提供了高级处理参数,包括分辨率带宽(RBW)、加窗、滤波、单位转换和各种频谱均值法。
    发布日期:2012/02/03
    包含的版本:2.6.3
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    文件大小: 666796640 字节 (635.91 MB)
    修改日期: 2022-03-25 06:09
    MD5: 1f03cd4954d9fb7e92cdcf48f185d1ca
    SHA1: bdd0abf779e0dee59362d252a9ea015e936f466b
    SHA256: d1b9bdd75eb67257f3bfd1ec922dc83dc1b9df9a93f51e5906ad32639b040c2e
    CRC32: 1f814358
    请注册登录视觉论坛账号,购买附件查看下载地址
    SMT2.6.3.txt (499 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Spectral Measurements Toolkit Readme
    Version 2.6.3
    Thank you for using the NI Spectral Measurements Toolkit (SMT). This file contains important information about the toolkit and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Licensing
    • Supported Drivers
    • Examples
    • Documentation
    • Uninstalling/Modifying NI Spectral Measurements Toolkit
    • Known Issues
    • Bug Fixes
    • Notice Regarding Microsoft Silverlight Installation and Redistribution
    NI Spectral Measurements Toolkit 2.6 includes the following new features:
    • Support for generating and applying pulse shaping filter on user-defined regions of a given spectrum through the addition of a new palette-level VI—SMT Filter Spectrum VI
    • Addition of the SMT Spectrum Peak Search (Advanced VI), and the SMTSpectrumPeakSearchMaxNPeaks function
    NI Spectral Measurements Toolkit 2.5 includes the following new feature:
    • Japanese localization for LabVIEW application programming interface (API) and documentation
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    NI Spectral Measurements Toolkit 2.6.3 and later support the following operating systems:
    • Windows XP (32-bit)
    It is recommended that you have the most recent service pack for your operating system installed.
    NI Spectral Measurements Toolkit 2.6.3 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • 3 GB of free hard drive space
    • RAM—256MB
    Recommended System
    NI recommends that your system meets the following requirements:
    • 4 GB of free hard drive space
    • RAM—1GB
    Note:  The SMT run-time Engine must be installed on systems running applications built using the NI Spectral Measurements Toolkit and LabWindows/CVI. The SMT run-time installer is available on the NI Spectral Measurements Toolkit CD in the NISMTCVIRTE folder (setup.exe).
    • LabVIEW 8.6.1, 2009 SP 1 (32-bit), 2009 SP 1 (64-bit), 2010 SP 1 (32-bit), 2010 SP 1 (64-bit), 2011 SP1 (32-bit), or 2011 SP1 (64-bit)
    • LabVIEW Real-Time Module 8.6.1, 2009 SP 1, 2010 SP 1, or 2011
    • LabWindows™/CVI™ 9.0, 2009, 2010, or 2011
    Licensing
    For details on activating the NI Spectral Measurements Toolkit, refer to the Activating Your Software section in the LabVIEW help file. The evaluation mode for the NI Spectral Measurements Toolkit is 30 days from the date of installation. You can access all the features of the toolkit in the evaluation mode. Refer to the software license file for further licensing requirements.
    Note:  Licensing is available only for LabVIEW.
    Supported Drivers
    Install all the instrument drivers for the hardware you intend to use before installing the NI Spectral Measurements Toolkit. The toolkit supports the following drivers:
    • NI-RFSA 2.1 or later
    • NI-SCOPE 3.4 or later
    If you install one or more of the aforementioned drivers after installing the NI Spectral Measurements Toolkit 2.6.3, driver-specific toolkit examples and palette VIs are not present. To install these driver-specific files, you must run the Modify function from the NI Spectral Measurements Toolkit installer. To do so, follow the instructions found in the Uninstalling/Modifying NI Spectral Measurements Toolkit section.
    Verify that LabVIEW and/or CVI and any supported drivers you intend to use with the toolkit are installed on your system prior to installing the toolkit. Install the toolkit by inserting the toolkit CD into your drive and clicking setup.exe.
    Note:  When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run the installer in silent mode from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
      • Windows XP: \All Users\Shared Documents\National Instruments
      • Windows 7/Vista: \Public\National Instruments
      • Windows 7 (32-bit)/Vista (32-bit)/XP (32-bit)
        • LabVIEW (32-bit): Program Files\National Instruments
      • Windows 7 (64-bit)/Vista (64-bit)/XP (64-bit)
        • LabVIEW (32-bit): Program Files(x86)\National Instruments
        • LabVIEW (64-bit): Program Files\National Instruments
      • LabVIEW 8.6.1: \LabVIEW 8.6.1
      • LabVIEW 2009 SP1 (32-bit): \LabVIEW 2009
      • LabVIEW 2009 SP1 (64-bit): \LabVIEW 2009
      • LabVIEW 2010 SP1 (32-bit): \LabVIEW 2010
      • LabVIEW 2010 SP1 (64-bit): \LabVIEW 2010
      • LabVIEW 2011 SP1 (32-bit): \LabVIEW 2011
      • LabVIEW 2011 SP1 (64-bit): \LabVIEW 2011
    FilesInstalled Location
    VIs\vi.lib\addons\Spectral Measurements Toolset
    Examples\examples\Spectral Measurements Toolset
    LabWindows/CVI
    Header Files\Shared\CVI\Include
    Static Libraries (32-bit)\Shared\CVI\Bin\msvc
    Static Libraries (64-bit)\Shared\CVI\Bin\msvc64
    .lfp/.sub Files\Shared\CVI\Bin
    Examples\National Instruments\CVI\samples\smt
    C
    Header Files\Shared\ExternalCompilerSupport\C\include
    Import Library (32-bit)\Shared\ExternalCompilerSupport\C\lib32\msvc
    Import Library (64-bit)\Shared\ExternalCompilerSupport\C\lib64\msvc
    Notes On Creating Modulation Executables Using Spectral Measurements Toolkit and LabVIEW Application Builder, available on the National Instruments Web site, contains information about which VIs must be included as dynamic VIs in LabVIEW Application Builder for the executable file to run correctly.
    Examples
    LabVIEW users can use the NI Example Finder to search or browse examples. NI Spectral Measurements Toolkit examples are classified by keyword, so you can search for a particular device or measurements function. With LabVIEW running, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI Spectral Measurement Toolkit examples) and their descriptions.
    • Click the Browse tab to locate examples by task at Toolkits and Modules»Spectral Measurements or by directory structure at Spectral Measurements Toolset.
    • Click the Search tab to search all installed examples by keyword. For example, searching for "spectral" can be used to locate NI Spectral Measurements Toolkit examples.
    Note:  Links to the NI Spectral Measurements Toolkit examples are also available from the Start menu at All Programs»National Instruments»Spectral Measurements»LabVIEW Support and All Programs»National Instruments»Spectral Measurements»CVI Support.
    The product documentation is available at Start»All Programs»National Instruments»Spectral Measurements. Visit ni.com/manuals for the latest versions of product documentation. The documentation for the NI Spectral Measurements Toolkit includes the following items:
    • NI LabVIEW Spectral Measurements Toolkit Help
    • NI Spectral Measurements Toolkit Function Reference Help
    • NI Spectral Measurements Toolkit User Guide
    • NI Spectral Measurements Toolkit Readme (this document)
    Uninstalling/Modifying the NI Spectral Measurements Toolkit
    Perform the following procedure to uninstall NI LabVIEW Spectral Measurements Toolkit 2.6.3:
    • Click Change/Remove.
    • Select NI LabVIEW Spectral Measurements Toolkit 2.6.3 from the dialog box that appears.
      Note:  To uninstall or modify the NI Spectral Measurements Toolkit for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit 2.6.3 from the dialog box that appears.
      Note:  To uninstall or modify the NI Spectral Measurements Toolkit Runtime for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit Runtime 2.6.3 from the dialog box that appears.
    You can access the software and documentation known issues list online. Refer to the NI Spectral Measurements Toolkit 2.6, 2.6.1, 2.6.2, and 2.6.3 Known Issues List at ni.com for an up-to-date list of known issues in NI Spectral Measurements Toolkit 2.6.3.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.3 from NI Spectral Measurements Toolkit 2.6.2.
    320267Fixed an issue where license manager was unable to check out NI Spectral Measurements Toolkit license from certain packages in a volume license file.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.2 from NI Spectral Measurements Toolkit 2.6.1.
    309228Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Spectral Measurement Toolkit dependencies.
    307793Fixed an issue where the SMT filter spectrum function clears all the values of the spectrumInfo struct.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.1 from NI Spectral Measurements Toolkit 2.6.
    293100Fixed an issue where users were unable to install some of the components of the NI Spectral Measurements Toolkit on LabVIEW 2010.
    The following items are changes in NI Spectral Measurements Toolkit 2.6 from NI Spectral Measurements Toolkit 2.5.1.
    34854Fixed an issue where the SMT peak search routine does not detect peaks that fall on the power spectrum boundaries.
    The following items are changes in NI Spectral Measurements Toolkit 2.5.1 from NI Spectral Measurements Toolkit 2.5.
    198949Fixed an issue where Japanese language LabVIEW support may get installed for non-Japanese LabVIEW.
    Using Microsoft Silverlight
    © 2004–2012 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-15 13:43
