查看: 2607|回复: 0
[LV工具模块] LabVIEW Modulation Toolkit 4.4 Win32/64Eng LabVIEW调制工具包4.4
    11 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2022-12-5 12:47:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW调制工具包
    LabVIEW调制工具包为LabVIEW提供了调制信号生成和分析功能,适用于研究、设计、原型,验证和测试应用。
    LabVIEW调制工具包是LabVIEW的一个软件附件,提供了用于生成、分析、处理和可视化模拟和数字调制信号的功能和工具。该工具包可让您使用各种调制方案(包括AM、FM、PM、ASK、FSK、MSK、PSK和QAM)对信号进行调制和解调。使用LabVIEW调制工具包,您可以执行信道编码、交织编码和均衡等等高级信号处理,也可以测量频率误差、误差矢量幅度(EVM)和误码率(BER)等参数,以验证信号质量。使用LabVIEW调制工具包,您还可以应用常见的信号减损,并通过星座图、眼图和网格图等可视化工具查看信号。
    发布日期:2014/06/11
    包含的版本:4.4.0
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    文件大小: 541127456 字节 (516.06 MB)
    修改日期: 2022-03-25 16:49
    MD5: 6df3c64edf53fe4960daa15ec9a5dc66(秒传)
    SHA1: 14c65459a456a6cca70347dd82d4a1d781bd7ccd
    SHA256: 8889826e1f7ca0fbcdbc04267f639d52543f2a5071328bb50a2865ffd42d17e1
    CRC32: 777a1009
    请注册登录视觉论坛账号,购买附件查看下载地址
    Modulation4.4.txt (490 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW Modulation Toolkit Readme
    Version 4.4
    Thank you for using the NI LabVIEW Modulation Toolkit (MT). This file contains important information about the toolkit and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI LabVIEW Modulation Toolkit
    NI LabVIEW Modulation Toolkit 4.4 includes the following new features:
    • Support for LabVIEW 2013 and LabVIEW 2014
    • Support for Offset EVM measurement for OQPSK
    • Support for EVM normalization for QAM
    • Support for quadrature skew measurement for OQPSK
    NI LabVIEW Modulation Toolkit 4.3.4 adds support for LabVIEW 2012.
    NI LabVIEW Modulation Toolkit 4.3.2 adds support for LabVIEW 2011.
    NI LabVIEW Modulation Toolkit 4.3 includes the following new features:
    • Support for MLSE demapper for CPM and MSK
    • Support for non-systematic encoder-decoder for BCH and Hamming codes
    • Support for clock frequency offset estimation and correction for FSK, PSK, and QAM
    • Support for palette-level function for autoconfiguring and performing CCDF measurement
    NI LabVIEW Modulation Toolkit 4.2 includes the following new feature:
    Japanese localization for LabVIEW application programming interface (API) and documentation
    Supported HardwareVector Signal Generators
    • NI PXI-5670
    • NI PXI-5671
    • NI PXIe-5672
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Signal Generators Help.
    Arbitrary Waveform Generators
    • NI PXIe-5442
    • NI PXIe-5450
    • NI PXIe-5451
    Vector Signal Analyzers
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    NI LabVIEW Modulation Toolkit 4.4 and later supports the following operating systems:
    Note   NI LabVIEW Modulation Toolkit 4.4 and later does not support Windows Server non-R2 editions.
    NI LabVIEW Modulation Toolkit 4.4 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows 8.1/8/7/Vista: 2 GB*
      • Windows XP SP3: 256 MB*
    • Windows 8.1/8/7/Vista/XP SP3, with all available critical updates and service packs
    • If you are running your application on an RT target, 128 MB of memory or more is recommended.
    Recommended System
    • RAM—
      • Windows 8.1/8/7/Vista: 4 GB*
      • Windows XP SP3: 2 GB*
    Note   Instrument drivers are not required for NI LabVIEW Modulation Toolkit operation in simulation mode. However, the toolkit installs examples for the supported drivers if they are present on the system. Refer to the Supported Drivers section of this document for more information.
    Note  You should install ADEs, such as NI LabVIEW before installing NI LabVIEW Modulation Toolkit. To add support for ADEs installed after installing NI LabVIEW Modulation Toolkit, modify your NI LabVIEW Modulation Toolkit installation or launch the NI LabVIEW Modulation Toolkit installer again.
    • NI LabVIEW 2011 SP1 (32-bit and 64-bit), 2012 SP1 (32-bit and 64-bit), 2013 SP 1 (32-bit and 64-bit), 2014 (32-bit and 64-bit)
    • NI LabVIEW Real-Time Module 2011 SP1, 2012 SP1, 2013 SP 1, 2014
    Supported Drivers
    Install all the instrument drivers for the hardware you intend to use before installing the NI LabVIEW Modulation Toolkit. The toolkit supports the following drivers:
    • NI-RFSA 2.9 or later
    • NI-SCOPE 4.0.5 or later
    • NI-RFSG 1.9.7 or later
    • NI-FGEN 2.9.4 or later
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\National Instruments
      • Windows 8.1 (64-bit)/8 (64-bit) /7 (64-bit)/Vista (64-bit): Program Files (x86)\National Instruments
      • Windows 8.1/8/7/Vista/XP: \LabVIEW
    ItemInstalled Location on Windows 8.1/8/7/Vista/XP
    VIs\vi.lib\addons\Modulation
    Examples\examples\Modulation
    Documentation for NI LabVIEW Modulation Toolkit 4.4 is located at Start»All Programs»National Instruments»Modulation Toolkit. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI LabVIEW Modulation Toolkit HelpHTML/Windows HelpContains primary help content for NI LabVIEW Modulation Toolkit products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI LabVIEW Modulation Toolkit
    • A complete reference for all NI LabVIEW Modulation Toolkit programming functions and VIs
    NI LabVIEW Modulation Toolkit ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI LabVIEW Modulation Toolkit palette VIs are available from the Functions»RF Communications»Modulation palette.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI Modulation Toolkit examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and NI Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Toolkit and Modules»Modulation or by directory structure at Modulation.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Modulation" to locate all NI LabVIEW Modulation Toolkit examples.
    You can also access all the installed NI LabVIEW Modulation Toolkit examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»Modulation Toolkit»Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the NI LabVIEW Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    • Click Change/Remove.
    • Select NI LabVIEW Modulation Toolkit 4.4 from the dialog box that appears.
    For Windows 8.1/8, complete the following steps:
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    The following are the behavior changes in NI LabVIEW Modulation Toolkit 4.4 from NI LabVIEW Modulation Toolkit 4.3.4:
    • The VIs present on the palette, Functions»RF Communications»Modulation»MT 5620 Specific, are no longer in niAMT.lvlib. The location of these VIs on the disk has not changed.
      Applications using the VIs present on this palette need to be manually relinked.
    • The VIs present in the directories, /addons/Modulation/niFGEN, /addons/Modulation/niScope, and /addons/Modulation/RFSA, are no longer in niAMT.lvlib. The location of these VIs on the disk has not changed.
    • Removed Japanese localization support.
    • Changed the default 128-QAM symbol map to a non square map.
    • Updated the quadrature impairments results to return NaN when an error occurs while measuring.
    • Differential M-PSK mapping using custom symbol map has been modified. The differential map is derived by rotating the symbol map by -PI/M radians instead of the phase of the first symbol in the map.
    You can access the software and documentation known issues list online. Refer to the NI LabVIEW Modulation Toolkit 4.4 Known Issues at ni.com for an up-to-date list of known issues in NI Modulation Toolkit 4.4.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.4 from NI LabVIEW Modulation Toolkit 4.3.4.
    389508Fixed DWarn 0x262C7578.
    402017Fixed an issue where MSK demodulation returned a high EVM.
    462305Fixed an issue where MSK recovered an incorrect constellation when the pulse shaping filter was set to None.
    362507Fixed an issue where installing MT 4.3.3 did not install digital modulation related files on LabVIEW 2012.
    404991Fixed an issue where controls could not be created for Modulation Toolkit classes.
    415930Fixed an issue where the OQPSK demodulation did not lock to the constellation consistently.
    426459Fixed an issue where EVM variations were observed in 8-PSK and 16-PSK demodulation.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.4 from NI LabVIEW Modulation Toolkit 4.3.3.
    362507Fixed an issue where installing NI LabVIEW Modulation Toolkit 4.3.3 did not install Digital Modulation Toolkit VIs on LabVIEW 2012.
    374121Fixed an issue where NI LabVIEW Modulation Toolkit did not install on LabVIEW 2012.
    404822Fixed an issue where multiple shortcuts to documents were present in the Start Menu folder for NI LabVIEW Modulation Toolkit.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.3 from NI LabVIEW Modulation Toolkit 4.3.2.
    322185Fixed an issue where some files were missing in the Modulation Toolkit after upgrading LabVIEW and reinstalling the toolkit for the upgraded version.
    320449Fixed an issue where license manager was unable to check out Modulation Toolkit license from certain packages in a volume license file.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.2 from NI LabVIEW Modulation Toolkit 4.3.1.
    294171Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Modulation Toolkit dependencies.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.1 from NI LabVIEW Modulation Toolkit 4.3.
    294170Fixed an issue where LabVIEW projects that have Modulation Toolkit dependencies take a long time to load.
    294916Fixed an issue where an error message is displayed while compiling a project that refers to mod_Symbols to Bits.vi.
    298309Fixed an issue where analog modulation VIs are not installed on upgrading from MT 4.1 to 4.3.1.
    293100Fixed an issue where Modulation Toolkit does not install properly on LabVIEW versions after 2010 SP1.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3 from NI LabVIEW Modulation Toolkit 4.2.1.
    147127Fixed an issue where the offsets seem to be off by one sample in the MT Phase Noise example.
    176993Fixed an issue where the sideband rejection in AM-SSB is correlated to the sample rate of the message signal, and cannot be reduced below a certain dB level.
    223422Fixed an issue where the Gaussian pulse does not integrate to unity.
    233207Fixed an issue in FSK modulation, where the pulse shape filter rampup that needs to be deleted must be equal to the length of the filter.
    239324Fixed an issue where the search (+/- % of Fsampl) parameter of the pilot extraction filter cluster is used incorrectly during AM-SSB and AM-VSB demodulation.
    244292Fixed an issue where the constellation trace shows ghost points when a BPSK symbol is defined in PSK simulation.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    NI LabVIEW Modulation Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Modulation Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW Modulation Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2002–2014 National Instruments. All rights reserved.
    GMT+8, 2026-4-8 19:43
