查看: 8886|回复: 2
[LV工具模块] LabVIEW 2018 Datalogging and Supervisory Control Module Win32Eng LV2018数据记录和监控模块DSC2018
    昨天 08:07
  • 签到天数: 3851 天
    连续签到: 44 天
    发表于 2020-2-23 18:38:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址(可能无效或无法下载完成)(EXE与ZIP内容一样,EXE为NI当年发行时的版本,ZIP为NI后面重新压制的版本):
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    DSC2018.txt (874 Bytes, 下载次数: 39, 售价: 10 圆)
    LabVIEW 2018 Datalogging and Supervisory Control Module Readme
    March 2018
    This file contains important information about the LabVIEW Datalogging and Supervisory Control (DSC) Module, including installation instructions, known issues, and a partial list of bugs fixed for the LabVIEW 2018 DSC Module.
    The LabVIEW DSC Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
    In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
    • LabVIEW 2018 Base, Full, or Professional Development System (32-bit)
    • At least 2.5 GB of disk space
    • 512 MB of RAM. NI recommends 1 GB of RAM.
    • Internet Explorer 6 Service Pack 1 or later
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018.
    Note  The DSC Module is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS.
    The DSC Module supports the following operating systems:
    • Windows 10 (version 1709)/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 the LabVIEW DSC Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 DSC Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 DSC Module to an unsupported OS. Additionally, after installing the LabVIEW 2018 DSC Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2018 Platform media.
    • The DSC Module requires the Microsoft SQL Server 2008 R2 Express. This component is installed by default when you install the DSC Module. Visit ni.com/info and enter the Info Code exafvc for information about how to configure the Microsoft SQL Server.
    Licensing
    The DSC Module relies on licensing activation. When the evaluation period expires, you must activate a valid DSC Module license to continue using the DSC Module.
    The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the DSC Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2018 DSC Module. This is not an exhaustive list of issues fixed in the current version of the DSC Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    652654LabVIEW crashes when calling the Undeploy Libraries VI on an array of uninitialized path constants.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help, for information about the DSC Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2000–2018 National Instruments. All rights reserved.
    375310D-01
  • 签到天数: 1 天
    发表于 2022-12-23 19:39:38 | 显示全部楼层 来自:河北省廊坊市 电信
  • 签到天数: 1 天
    发表于 2022-12-23 19:39:59 | 显示全部楼层 来自:河北省廊坊市 电信
    石鑫华视觉网,工业相机、工业镜头、机器视觉光源、光源控制器、图像处理、系统集成服务商
    GMT+8, 2026-4-10 04:10
