查看: 2221|回复: 0
[RTE运行引擎] NI RFmx Demod/Analog Modulation/Digital Modulation 3.0 Runtime Win64Eng RFmx解调/模拟调制/数字调制3.0运行版
    昨天 08:07
  • 签到天数: 3851 天
    连续签到: 44 天
    发表于 2022-1-6 16:37:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    RFmx Analog Modulation是运行在RFmx解调器内的应用软件,它与RFmx Analog Modulation一起安装。该软件可扩展NI RF仪器对于模拟调制信号生成和分析的能力。您可以使用该软件,通过对频率/相位偏移、模拟调制深度、频率/相位偏差等的测量,分析AM、FM、PM和FM的立体声信号。此外,您可以通过应用去加重和音频滤波器来分析解调后的信号波形、频谱和失真。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    3.0RTEx64
    文件大小: 309665808 字节 (295.32 MB)
    修改日期: 2019-01-18 18:53
    MD5: 3465d44561c03cef871317cb113e92d9
    SHA1: e2abe6d8d90a291ecb770a52a90106a4f66c62e1
    SHA256: 1fed6b8f6b6186de147d55bea42b9e7c808d4773b6a07fb60f592882930a8ed0
    CRC32: 925e5cd8
    NI官方下载和百度网盘下载地址:
    RFMXdemod3.0RTEx64.txt (533 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx Demod 3.0 Readme
    January 2019
    This file contains important information about NI-RFmx Demod and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx Demod 3.0 includes the following new features:
    • Support for NI PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    NI-RFmx Demod 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxDemod Commit API
    NI-RFmx Demod 2.3.1 includes the following new features:
    • Support for CFO estimation mode
    • Support for Search Length attribute to decouple acquisition time and number of symbols to measure
    NI-RFmx Demod 2.3 includes the following new features:
    • Support for Burst Analysis in DDemod
    • Support for Linearized GMSK Pulse Shaping Filter and 3*Pi/8 - 8PSK modulation for EDGE DDemod
    • Support for enabling or disabling IQ offset correction in EVM measurement
    Caution Before you install NI-RFmx Demod 3.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    Caution If you are using only RFmx LabVIEW Runtime products, NI recommends uninstalling all the RFmx Runtime products before installing a newer version of RFmx Runtime products.
    Note  Some of the installed NI-RFmx Demod.NET examples require the NI-RFSG .NET Class Library. For these examples to build and run successfully, install NI-RFSG .NET Class Library before or after installing NI-RFmx Demod.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI-RFmx Demod 3.0 supports the following operating systems:
    Note  In 2016, NI-RFmx Demod dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx Demod 3.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx Demod 3.0 to an unsupported OS. Additionally, after installing NI-RFmx Demod 3.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx Demod 3.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI, or Microsoft Visual Studio®, before installing NI-RFmx Demod. To add support for ADEs installed after installing NI-RFmx Demod, modify your NI-RFmx Demod installation or launch the NI-RFmx Demod installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    • NI LabWindows/CVI 2010 or later
    Note  NI-RFmx Demod does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.0.1 or later
      • (64-bit OS) Program Files (x86)\National Instruments
      • (32-bit) windows\system32
    ItemInstalled Location
    Function Panels
    \Shared\CVI\Bin\niRFmxDemod.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET, NI TestStand
    Examples\NI-RFmx\Demod\Examples
    LabWindows/CVI
    Examples\CVI\samples\NI-RFmx\Demod
    Examples\LabVIEW \examples\RFmx\Demod
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Measurement Interactive Panel to launch the NI-RFmx Demod Measurement Interactive Panel.
    Documentation for NI-RFmx Demod is located at Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx Demod HelpHTML/Windows HelpInformation about NI-RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx Demod
    • A complete reference for all NI-RFmx Demod programming functions and VIs
    NI-RFmx Demod 3.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx Demod palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx Demod functions are available in LabWindows/CVI from the Library»RFmx Demod Library menu.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFmx Demod examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFmx» Demod or by directory structure at RFmx» Demod.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Demod" to locate all NI-RFmx Demod examples.
    You can also access all the installed NI-RFmx Demod examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx Demod»NI-RFmx Demod Examples.
    Refer to ni.com/examples for these examples and for more information.
    The following items are the behavior changes in NI-RFmx Demod 2.3.1 from NI-RFmx Demod 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@Demod' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    No known issues.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx Demod. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx Demod. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx Demod 3.0 from NI-RFmx Demod 2.5
    706047Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the NI-PXIe-5840.
    The following items are changes in NI-RFmx Demod 2.5 from NI-RFmx Demod 2.4.
    644169Fixed an issue to enhance the CFO estimation for QAM.
    699425Fixed an issue to align the Quadrature skew definition with NI-RFmx Waveform Creator.
    The following items are changes in NI-RFmx Demod 2.4 from NI-RFmx Demod 2.3.1.
    656549Fixed an issue with EVM measurements resulted from the IQ imbalance application to half-sine filtered OQPSK signal.
    656458Fixed an issue with impairments estimation of OQPSK modulated signal.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    641411Fixed an issue with running DDEM measurement with Auto Level.
    © 2014–2019 National Instruments. All rights reserved.
    374855K-01
    GMT+8, 2026-4-10 03:38
