查看: 2459|回复: 0
[NI软件产品] NI OPC Servers 2013 Win32/64Eng NI OPC服务器2013
    昨天 16:03
     楼主| 发表于 2022-12-1 10:35:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    OPC Servers
    OPC服务器提供单一、一致的接口,可通过OPC标准与多个设备通信。
    OPC服务器是LabVIEW的一款附加软件,可将专用工业协议转换为开放式OPC Classic和OPC统一架构(UA)协议。通过该转换,LabVIEW应用程序就可以通过LabVIEW OPC UA工具包附带的OPC UA客户端,与许多不同的可编程逻辑控制器(PLC)和第三方设备进行通信,因而用户只需在一个平台上即可对工业系统进行高性能测量和控制。
    NI OPC Servers 2013
    发布日期:2013/6/7
    包含的版本:2013完整版
    受支持的操作系统
    Windows 7
    Windows Server 2008 R2 64-bit
    Windows Server 2003 R2 32-bit
    Windows XP 32-bit
    Windows Vista
    Windows 8
    文件大小: 203641632 字节 (194.21 MB)
    修改日期: 2013-08-07 21:54
    MD5: f2f12eabeb5f213dd9ccfb57686e97ed(官方正确)
    SHA1: eea8cc95224c56415f33c8ebc0a71a86586bdd5c
    SHA256: 55d2a53a60233acc2000937a084c16684774df6d4db9b4fa04bf9df65b50cd47
    CRC32: d123ca1a
    请注册登录视觉论坛账号,购买附件查看下载地址
    OPC Server2013.txt (499 Bytes, 下载次数: 2, 售价: 10 圆)
    National Instruments OPC Servers 2013 Readme
    June 2013
    This file contains important information about the National Instruments OPC Servers (NI OPC Servers), including system requirements, installation and activation instructions, and a list of new features and changes.
    Licensing and Activation
    Drivers Usage
    New Features and Changes
    New Drivers and Changes
    NI OPC Servers provides a single consistent interface to communicate with multiple devices, saving you from learning new communication protocols and spending time understanding new applications. The combination of NI OPC Servers and other NI products, such as LabVIEW, the LabVIEW Datalogging and Supervisory Control (DSC) Module, Lookout, Measurement Studio, and LabWindows™/CVI™, provides a single platform for delivering high-performance measurements and control to new and existing industrial systems.
    You can use NI OPC Servers with the following software applications:
    • LabVIEW 2013 Full or Professional Development System
    • LabVIEW DSC Module 2013
      Note  The DSC Module must be the same version as LabVIEW.
    • Lookout 6.6
    By default, NI OPC Servers installs with the DSC Module for a two-hour evaluation period and with Lookout fully-licensed. NI OPC Servers connects through the OPC client in the DSC Module to enable you to develop a full-fledged Human Machine Interface (HMI) and Supervisory Control and Data Acquisition (SCADA) system with programmable logic controllers (PLCs), programmable automation controllers (PACs), and smart sensors.
    NI OPC Servers has both software and hardware minimum system requirements. This application supports the following operating systems:
    • Windows XP Service Pack 3 or later
    Note  NI OPC Servers does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    NI OPC Servers requires the following minimum hardware requirements:
    • 2.0 GHz processor
    • 1 GB installed RAM
    • 180 MB available disk space
    • Ethernet card
    • Super VGA (800x600) or higher resolution video card
    • CD-ROM or DVD Drive
    By default, NI OPC Servers installs with the DSC Module for a two-hour evaluation period and with Lookout fully-licensed. Complete the following steps to install NI OPC Servers if you purchased NI OPC Servers separately from the DSC Module or Lookout.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert the NI OPC Servers installation media and follow the instructions that appear on the screen.
    • Activate NI OPC Servers using the NI License Manager.
    NI OPC Servers Updates and Notifications
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter info code updates to access this information.
    NI OPC Servers installed with Lookout is licensed. NI OPC Servers installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using NI OPC Servers after the evaluation period expires.
    Use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate NI products. (Windows 8) Click NI Launcher and select NI License Manager in the window that appears. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the NI License Manager, for information about activating NI products.
    Drivers Usage
    NI OPC Servers supports numerous drivers for communication to third-party devices. You can connect to one driver at a time or an unlimited number of drivers simultaneously. To learn about driver usage in NI OPC Servers and to determine the number of drivers you can simultaneously connect to, visit ni.com/info and enter the info code opcdriverusage.
    This section lists the new features in NI OPC Servers 2013 and changes from NI OPC Servers 2012.
    Server Administration
    Moved the User Manager from a separate dialog that was launched from the Administration menu to a tab in the Settings dialog (which is located through the Administration menu by clicking Settings | User Manager).
    Enhanced the User Manager by adding granularity to specify whether users can modify channels, devices, and tags. Added a built-in user profile called ¡°Data Client¡± to control whether clients can access Dynamic (Native) Tags.
    Server Runtime
    Added a new OPC Diagnostic message to indicate that the client-supplied shutdown notification sink is being called. The new filter "ShutdownRequest" was added to the Filter dialog beneath "IConnectionPoint (Server)" to enable this event. It is displayed in the OPC Diagnostics View as "Calling registered shutdown sink". The detail shows the return value from the call as "Client returned =
    Altered the shutdown sequence to ensure that the OPC Diagnostics generated during Runtime shutdown will be delivered to the Configuration before it disconnects.
    Upgraded OPC Core Components to version 3.00.105.1. This version resolves conflicts between x64 and x86 versions of OpcEnum.
    Server Configuration
    Removed the Diagnostics sub-menu from the View menu, and then moved items from the Diagnostics sub-menu to the View menu.
    Added a device detail view to the server's right pane. When a channel is selected, the right pane will now display a list of devices that are assigned to that channel.
    Provided the ability to enforce a scan rate floor or fixed scan rate when polling underlying data sources. This feature can override the rates requested by client applications.
    Server Event Log
    Improved the Event Log's performance by increasing the number of records sent per packet.
    Added new persistence settings to support extended data storage. These settings are configured from the Event Log tab in the Settings dialog.
    Client Interfaces
    Added the ability to modify the advanced OPC UA Server properties MaxDataQueueSize, MaxNotificationsPerPublish, and MaxRetransmitionQueueSize.
    This section lists the new drivers in NI OPC Servers 2013 and changes from NI OPC Servers 2012.
    NI OPC Servers 2013 supports the following new drivers:
    • Allen-Bradley ControlLogix Unsolicited Ethernet—This driver is licensed with the Allen-Bradley Driver. This driver is intended for customers that require the use of CIP Data Table Read and Write Messages from the Logix family of controllers and need to communicate with a driver in an OPC server.
    • MTConnect Client—This driver connects to agents using the MTConnect Standard over HTTP.
    • OPC XML-DA Client—This driver is used to connect to Third-Party OPC XML-DA Servers.
    For a complete list of drivers that NI OPC Servers supports, visit ni.com/info and enter the info code opcdriverlist.
    NI OPC Servers 2013 includes the following changes to drivers:
    • Provided the ability to enforce a scan rate floor or fixed scan rate when polling underlying data sources. This feature can override the rates requested by client applications.
    • Enhanced XML support to always encrypt passwords before persisting to file, while maintaining backward compatibility with previous un-encrypted passwords. In doing so, password encryption with OpenSSL was strengthened where practical. This applies to new projects created with V5.6 and beyond.
    Refer to the National Instruments Web site at ni.com/opc or the NI OPC Servers Help, available by selecting Start»All Programs»National Instruments»OPC Servers 2013»OPC Servers Help, for more information about NI OPC Servers. (Windows 8) Click NI Launcher and select OPC Servers 2013»OPC Servers Help in the window that appears.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI OPC Servers Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments OPC Servers will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI OPC Servers that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2007–2013 National Instruments. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in NI OPC Servers, refer to the NI_OPC_Servers_notice.pdf file located in the National Instruments\Shared\NI OPC Servers\V5 directory.
    GMT+8, 2026-2-24 21:53
