查看: 1666|回复: 0
[NI软件产品] NI SignalExpress 2011 Win32德语/日语/法语/英文 数据记录软件Signal Express 2011
  • 签到天数: 3782 天
    连续签到: 33 天
     楼主| 发表于 2022-12-7 15:31:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2011/6/23
    包含的版本:2011
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 817576544 字节 (779.70 MB)
    修改日期: 2012-02-21 00:51
    MD5: a715597f329ddabc17ff86c2f5000dd9(官方正确)
    SHA1: df2424e974b2f48aac9ee9b3d00fcd577ec40fea
    SHA256: 387e2de830d34cb7c56e29923436e8ed945b68769e22f8ba38779a6544bd4399
    CRC32: bb44be5d
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress2011.txt (590 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW SignalExpress 2011 Readme
    Version 5.0.0
    June 2011
    This file contains important information about LabVIEW SignalExpress 2011, including known issues, installation instructions, and compatibility issues.
    Refer to the Getting Started with LabVIEW SignalExpress manual for getting started information by selecting Help»Getting Started with»LabVIEW SignalExpress in LabVIEW SignalExpress.
       Installing from the LabVIEW 2011 Platform DVDs
       Installing from the LabVIEW SignalExpress 2011 Installation Media
       Using Hardware with LabVIEW SignalExpress
    Activating LabVIEW SignalExpress
       LabVIEW SignalExpress Full Edition
       LabVIEW SignalExpress LE
    Compatibility
    Code Generation Compatibility
    LabVIEW SignalExpress is an interactive measurement program you can use to acquire, analyze, log, and present data from hundreds of data acquisition devices and instruments with no programming required. You can acquire signals from hardware devices installed on your computer, analyze the signals, and then send the resulting signals to hardware devices.
    LabVIEW SignalExpress runs as a 32-bit application on all operating systems.
    Your system must meet the following requirements to run LabVIEW SignalExpress:
    • 1 GB of memory
    • 2 GB of free disk space
    • Pentium 4 processor or equivalent
      • Windows XP SP2 (32-bit) or later
      Note  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). Refer to the National Instruments Web site to learn how disabling might affect your use of Windows Server 2003 and what actions you might have to take.
    LabVIEW SignalExpress does not support Windows 2000/NT/Me/98/95, Windows XP (64-bit), or the Windows Server non-R2 editions.
    Installation InstructionsInstalling from the LabVIEW 2011 Platform DVDs
    If you purchased LabVIEW 2011, you can install all of your LabVIEW products—including LabVIEW SignalExpress—using the LabVIEW 2011 Platform DVDs. Find installation instructions for LabVIEW SignalExpress, along with activation instructions, in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Complete the following steps to install LabVIEW SignalExpress 2011 from the LabVIEW SignalExpress installation media.
    • Insert the LabVIEW SignalExpress 2011 installation media and follow the instructions that appear on the screen.
    • (Optional) Activate LabVIEW SignalExpress when prompted by the installer, or activate at a later time using the NI License Manager.
    Complete the following steps to use LabVIEW SignalExpress with hardware.
    • Install the appropriate driver software, according to the following table.
      HardwareDriver software
      Multifunction DAQNI-DAQmx
      high-speed digitizersNI-SCOPE
      signal generatorsNI-FGEN
      digital multimetersNI-DMM
      All driver software is available on the Driver DVD.
    • Shut down the computer.
    • Install the hardware.
    • Restart the computer to complete the software installation.
    LabVIEW SignalExpress is available in full and limited (LE) versions. When you install LabVIEW SignalExpress, you have a 30-day trial of the full edition. After that period, you must purchase the Full Edition or activate LabVIEW SignalExpress LE.
    If you purchased the Full Edition of LabVIEW SignalExpress, you can activate from the software or the NI License Manager using the serial number included in your software kit. If you purchased the Full or Professional Edition of LabVIEW 2011, you can use the serial number included with LabVIEW 2011 to activate LabVIEW SignalExpress. Refer to the National Instruments Web site at ni.com/signalexpress to purchase the Full Edition.
    LabVIEW SignalExpress Limited Edition (LE)
    You can activate LabVIEW SignalExpress LE by clicking the Register Limited Edition button on the National Instruments License Dialog window that appears when you launch the application. You also can activate LabVIEW SignalExpress LE from the NI License Manager using the following serial number:
    S14X86756
    Refer to the LabVIEW SignalExpress Help by selecting Help»LabVIEW SignalExpress Help for information about LabVIEW SignalExpress.
    You can modify an example project for an application, or you can copy and paste one or more examples into a project that you create. Example projects for LabVIEW SignalExpress are located in the signalexpress\examples directory. You can find the examples directory in one of the following ways:
    • Click Open Example Project for LabVIEW SignalExpress from the Getting Started window.
    • Select Help»Open Example from LabVIEW SignalExpress.
    Compatibility
    LabVIEW SignalExpress is compatible with the following products:
    • NI-DAQmx 8.5 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DMM 2.4.1 or later
    • NI-DCPower 1.0 or later
    • IVI Driver Toolset 2.0 or later
    LabVIEW SignalExpress installs the NI Measurement Studio Network Variable and WindowsForms support in the .NET Global Assembly Cache for run-time purposes.
    To convert a LabVIEW SignalExpress project to a LabVIEW VI, you must have the LabVIEW 8.6 Full Development System or later installed.
    Note  LabVIEW SignalExpress does not support the 64-bit versions of LabVIEW.
    The Run LabVIEW 7.1 VI, Run LabVIEW 8.0 VI, Run LabVIEW 8.2 VI, and Run LabVIEW 8.5 VI steps are deprecated in LabVIEW SignalExpress 2011. To run a project that contains these steps, download and install the appropriate support package from ni.com:
    • Run LabVIEW 7.1 VI Step Support
    • Run LabVIEW 8.0 VI Step Support
    • Run LabVIEW 8.2 VI Step Support
    • Run LabVIEW 8.5 VI Step Support
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW SignalExpress 2011.
    The following table contains the IDs and titles of a subset of issues fixed for LabVIEW SignalExpress 2011. This table is not an exhaustive list of issues fixed in the current version of LabVIEW SignalExpress. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    142793Two (or more) sequence steps prevent execution past the first one
    163506Changing the acquisition rate while project is running may cause a loss of viewable data in the digital display.
    208256Load from LVM step does not recognize when a file no longer exists. Instead it executes and an error is not displayed to the user.
    217339When creating a log subset, if the dialog is cancelled before it becomes fully initialized, LabVIEW SignalExpress can crash.
    224804On first addition of data to scalar displays, autoscaling may fail to correctly envelope the data.
    232471Stop Condition doesn't work if only the second of two signals is being recorded.
    236147A pre-LabVIEW 2009 Run LabVIEW VI Step with an array of double datatype crashes LabVIEW SignalExpress
    249273Lower Limit value is ignored as Start Condition in Remote Options whenever defined in an entering window or leaving window for tasks configured for 1 Sample On Demand.
    257848Saving "response signal (real)" of a frequency response step to an ASCII/LVM file makes LabVIEW SignalExpress hang when choosing the signal in the saving step.
    277537Configuring an IVI FGEN Standard Function fails to recognize IVI session name and populate channel list. User receives Primary Error: (Hex 0xBFFA000F) Invalid parameter.
    Important Information
    © 2004–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-24 14:11
