查看: 7238|回复: 1
[NI驱动程序] NI Vision Acquisition Software 2011.03 LabVIEW2010SP1 Win32/64Eng 视觉采集软件VASMarch2011
    昨天 08:55
  • 签到天数: 3849 天
    连续签到: 42 天
    发表于 2013-5-8 21:10:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI 视觉采集软件。集成大部分的标准工业相机驱动程序。安装后,如果是标准接口工业相机,可以实现在MAX、LabVIEW、Vision Assistant、VBAI等软件中实现相机驱动与图像采集功能。石鑫华视觉珍藏。
    文件大小: 1334331139 字节 (1.24 GB)
    修改日期: 2019-01-03 14:10
    MD5: a3c41109db47f0ba40564778c5d8c2aa(官方正确)
    SHA1: 03c1637ea8ae5b79a2b1cecb176817c0936d2571
    SHA256: 23e0ca518ee3249498215b984bb921681abb65d49155f87f0790a60ab4032f87
    CRC32: 0a80a04d
    百度网盘下载:1.24GB
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    VAS2011.03.txt (219 Bytes, 下载次数: 30, 售价: 10 圆)
    NI Vision Acquisition Software Release Notes
    March 2011
    This file contains important information about National Instruments Vision Acquisition Software, and is organized into the following sections:
    Upgrade Considerations for Legacy NI-IMAQ for IEEE 1394 Cameras
    Minimum System Requirements
    Software Support
    Installation
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    NI Vision Acquisition Software allows you to acquire, display, and save images; control digital I/O on National Instruments image acquisition devices; and configure your driver software and hardware.
    The readme.html file for each NI Vision Acquisition Software driver is installed to the following default locations, where is the location to which National Instruments software is installed. For a list of known issues, refer to the individual driver readmes.
    • NI-IMAQ\NI-IMAQ\Docs\readme.html
    • NI-IMAQdx\NI-IMAQdx\Docs\readme.html
    • NI-IMAQ I/O\NI-IMAQ IO\Docs\readme.html
    This release of Vision Acquisition Software includes the following new features:
    NI-IMAQ 4.6
    NI-IMAQ is driver software for NI 17xx smart cameras, as well as analog, parallel digital, and Camera Link image acquisition devices.
    • Support for the NI PXIe-1435 frame grabber
    • Support for atomic pulse updates
    NI-IMAQdx 3.8
    NI-IMAQdx is driver software that supports IEEE 1394, GigE Vision, DirectShow-compatible USB, and IP cameras.
    • Support for GigE Vision 1.2
    • Support for GenICam 2.1.1
    NI-IMAQ I/O 2.4.1
    NI-IMAQ I/O is the National Instruments I/O device driver software for controlling the digital I/O on IEEE 1394 hardware.
    NI-IMAQdx no longer supports Legacy NI-IMAQ for IEEE 1394 Cameras. This version of NI-IMAQdx uninstalls the Legacy NI-IMAQ for IEEE 1394 Cameras feature of NI-IMAQdx 3.3 or earlier. If you require Legacy NI-IMAQ for IEEE 1394 Cameras, you must download and install it separately. Visit ni.com/infoand enter the info code legacy1394 for information about how to install Legacy NI-IMAQ for IEEE 1394 Cameras. This version of NI-IMAQdx does not affect separate installations of Legacy NI-IMAQ for IEEE 1394 Cameras.
    The development computer must meet the following requirements to run NI Vision Acquisition Software:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    Minimum Recommended
    Free Hard Disk Space
    2 GB
    NI-IMAQ
    1 GB
    NI-IMAQdx
    1 GB
    NI-IMAQ I/O
    1.5 GB
    Operating System
    Windows 7/Vista/XP (32-bit)/Server 2008 R2/Server 2003 R2 (32-bit)
    Browser
    Microsoft Internet Explorer 5.0 or later
    Software Support
    This section describes the operating systems and application development environments (ADEs) supported by NI Vision Acquisition Software.
    Operating Systems
    • LabVIEW Real-Time Module 8.5 or later
    • Windows 7/Vista/XP (32-bit) SP2/Server 2008 R2/Server 2003 R2 (32-bit). Refer to the following table for more information.
    Note  NI Vision Acquisition Software does not support Windows Server non-R2 editions.
    DeviceWindows 7 32-bit/Windows Vista 32-bit/XP (32-bit)/Server 2003 R2 (32-bit)Windows 7 64-bit/Windows Vista 64-bit/Server 2008 R2
    NI 1405
    Yes
    Yes*
    NI 1407
    Yes
    Yes*
    NI 1408
    No
    No
    NI 1409
    Yes
    Yes*
    NI 1410
    Yes
    Yes*
    NI 1411
    Yes
    Yes*
    NI 1422
    Yes
    Yes*
    NI 1424
    Yes
    Yes*
    NI 1426
    Yes
    Yes*
    NI 1427
    Yes
    Yes*†
    NI 1428
    Yes
    Yes*
    NI 1429
    Yes
    Yes*†
    NI 1430
    Yes
    Yes*†
    NI 1433
    Yes
    Yes*†
    NI 1435
    Yes
    Yes*†
    NI 1473R
    Yes
    Yes*†
    NI 1483
    Yes
    Yes*
    NI 8231
    Yes
    Yes
    NI 8234
    Yes
    Yes
    NI 8235
    Yes
    Yes
    NI 8252
    Yes
    Yes
    NI 8254R
    Yes
    Yes
    NI 8255R
    Yes
    Yes
    *  Applications developed using LabVIEW 8.2.1 or later will run on systems with more than 3 GB of physical memory. Applications developed using other development environments, such as Microsoft Visual C, Visual Basic, and .Net, are limited to systems with 3 GB or less of physical memory. All 32-bit applications, including those developed using LabVIEW, may not allocate more than 2 GB of memory total.
    †  A firmware update is available for this device to allow non-LabVIEW applications to run on systems with more than 3 GB of physical memory. To update the device firmware, launch MAX and select Tools»NI Vision»Update NI-IMAQ Device Firmware.
    Development Environments
    • LabVIEW 8.5 and later
    • LabWindows/CVI 8.1 or later
    • Microsoft Visual C/C++ 6.0 or later
    • Microsoft Visual Basic 6.0 or later
    • Microsoft Visual Studio .NET 2005 and 2008 (except NI-IMAQ I/O)
    Additional Software
    You can also use NI-IMAQ, and NI-IMAQdx with the following National Instruments software packages to prototype, benchmark, and deploy your applications.
    • NI Vision Development Module 7.1 or later
    • NI Vision Builder for Automated Inspection (Vision Builder AI) 2.5 or later
    Complete the following steps to install NI Vision Acquisition Software:
    Note: You must have administrator access to install the NI Vision Acquisition Software.
    • Insert the NI Vision Acquisition Software installation media.
    NI-IMAQ and NI-IMAQdx integrate with MAX, the National Instruments utility for configuring and testing your measurement and automation system. The MAX icon appears on your desktop after you install NI Vision Acquisition Software.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ:
    • Run MAX.
      • Double-click the MAX icon on the desktop. You can use MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces and NI-IMAQ Devices to display a list of the image acquisition devices installed on your computer.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with MAX.
    Configuring a Remote PXI/Compact PCIe Image Acquisition Device
    Use MAX to install NI-IMAQ for LabVIEW Real-Time from the host machine onto the target system. The NI-IMAQ for LabVIEW Real-Time components enable the remote device to acquire and analyze images as directed by the host machine.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the MAX help window to install software.
    • Launch MAX.
    • Expand NI-IMAQ Devices.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to install and configure NI-IMAQdx.
    If you are using a USB camera, ensure that the camera is compatible with DirectShow, and that the camera driver is installed and functioning. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    Instructions for configuring an IEEE 1394 or GigE Vision camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    Installing IEEE 1394 Hardware
    Install your IEEE 1394 interface card. Follow the installation instructions provided by the manufacturer.
    • Install your NIC.
      • If Windows does not prompt you to choose a driver, proceed to step 2.
      • If Windows prompts you to choose a driver, proceed to step 3.
    • Choose not to connect to the Windows Update Web site, and click Next.
    • Choose to Install from a list or a specific location, and click Next.
    • Choose Don't Search. I will choose the driver to install.
    • Click Next.
    • Select National Instruments GigE Vision driver from the list, and click Next.
    • Click Finish.
      Note: Windows may return a warning stating that the driver is unsigned. It is safe to ignore the warning.
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps:
    Configuring Multiple Ports
    If you plan to use multiple ports with NI-IMAQdx, complete the following steps:
    • Open the Network Connections window in Windows, and select all of the ports that cameras will be connected to by holding while clicking each port.
    • Right-click one of the selected ports, and choose Bridge Connections.
      Note: If you are not using the High Performance Driver, you will be unable to use jumbo frames on bridged devices.
    Complete the following steps to configure NI-IMAQdx for Windows:
    • Connect the camera.
    • Run MAX.
      • Double-click the MAX icon on your desktop. You can use MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • For IEEE 1394 cameras, NI-IMAQdx may not be associated with the camera. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
    Configuring NI-IMAQdx for the LabVIEW Real-Time Module
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx:
    Note: NI-IMAQdx does not support USB cameras on the LabVIEW Real-Time Module.
    • Run MAX.
      • Configure your network settings. Refer to the Remote Systems Help in MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the RT target.
      • Click Install Software on the MAX toolbar to launch the LabVIEW Real-Time Install Software Wizard.
      • Select NI-IMAQdx RT, as well as any additional software you would like to install on the target machine.
      • Click Next to begin downloading the software to the target machine. When MAX has finished downloading the software, it restarts the remote device.
      • Click Finish.
    • Press to refresh the MAX configuration tree. Your camera should be listed in the Remote Systems list.
    The NI Vision Acquisition Software documentation is installed onto your hard drive with NI Vision Acquisition Software. The documentation ships as Adobe Acrobat portable document format (PDF) files and HTML Help files. To view the NI Vision Acquisition Software documentation, select Start»All Programs»National Instruments»Vision»Documentation.
    Note: You must have Adobe Acrobat Reader installed to view the PDFs. Refer to the Adobe Systems Incorporated Web site at www.adobe.com to download the latest version of Adobe Reader.
    NI LabVIEW Documentation
    You can access the NI-IMAQ VI Reference Help and the NI-IMAQdx VI Reference Help from the LabVIEW Help menu. In LabVIEW, select Help»NI Vision for LabVIEW Help.
    .NET Documentation
    The NI Vision Acquisition Software .NET documentation merges into the NI Measurement Studio Help. The NI Measurement Studio Help integrates into the Visual Studio Combined Help Collection under the Measurement Studio node in the Table of Contents. In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
    The NI Measurement Studio Help is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads. If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
    • NI Measurement Studio Help—Contains reference information about NI Vision for .NET objects. Describes how to create machine vision and image processing applications in Visual Basic .NET and C# using the NI Vision Development Module. You can launch the NI Measurement Studio Help in the following ways:
      If you have Measurement Studio installed:
      • From the Windows Start menu, select Start»All Programs»National Instruments»»Measurement Studio Documentation, where is the location to which Measurement Studio is installed. The help launches in a stand-alone help viewer.
      • From Visual Studio, select Measurement Studio»NI Measurement Studio Help.
      If you do not have Measurement Studio installed:
      • From Visual Studio, select Help»Contents to view the Visual Studio table of contents. The NI Measurement Studio Help is listed in the table of contents.
  • 签到天数: 16 天
    发表于 2014-1-3 10:52:23 | 显示全部楼层 来自:上海市 电信
    GMT+8, 2026-4-8 07:07
